Well i took the plunge. I installed a turbo on my 84 HJ60 with the 2h engine.
The goals are:
1. help engine perform and not smoke at altitude. I drive in a very wide variety of altitudes
2. Help engine tow my 1200lb mini-camper up to the mountains
3. keep boost around 8-10 max
4. not blow up the engine
5. not pay hardly anything for the upgrade.
Install conditions are:
0. install setup overview picture ; I decided to rotate the turbo 45 degrees from where folks normally install b/c my AC was in the way and too close to the exhaust or intake (crowded) The 45 out seemed to be a good compromise.
1. I went with the flipped manifold and a homemade flange adaptor. The flange was fully welded from the inside, photos below show tack/fit, i also felt the desiere to peen the cast steel for robustness with my trusty air hammer
2. I Ordered a CT26 17201-68010 (12HT turbo) from ebay store front for a turbo shop in Oakland CA. But a 17201-74010 was delivered (2.0L Celica version) to me instead. Figured this would work too so i went forward with it.
3. I have not yet installed an intercooler
4. I did install a Pyro/boost/temp gauge
5. I installed a blow off valve
6. The unit came with an external waste gate
7. I tapped the oil out from the alternator for the oil feed (turbo is clocked so that the oil can drain at shut off.
8. I tapped the water line pre-heater core and ran that in to. Water comes in the bottom and goes out the bottom.
9. I adjusted the fuel so that i could not exceed 1200F on the pyro worst case.
10. Blow off valve BOV vacuum is tapped into the injection pump vacuum line.
11. wrapped flange adaptors, down pipe with thermal barrier cloth stuff to prevent dumping heat into the engine bay (this is working great). AND wrapped the intake pipes to avoid engine heat bleed into my input air (i dont think this is working).
12. Down pipe outlet was 3" diameter and come to find out my exhaust pipe is only 2" and i currently have it necked down to this diameter.
Results are:
1. I am getting about 2psi at 1500 rpm and max out at about 7-10 PSI at 3000 depending on configuration(s) (UPDATED POST LEAK fixes: 2psi at 1500, 8 at 2100, 12 at 3000)
2. Waste gate adjustments i performed did nothing but lower boost pressure.
3. So the Waste gate is currently wired (almost) shut and the diaphragm is removed. Small play in wire to allow 1mm gap or less in gate results in a max of about 7 PSI with a normal conditions max boost of 5psi (FIXED)
4. Blow off valve BOV does not appear to do anything. I suspect vacuum isn’t enough to make it open.
5. No smoke at the tail
6. Decent performance increase (i did not dyno this b4 or after).
7. unsure of mileage change (originally 17mpg round town), too early to check, too many variables changing yet to measure
Notes / Watch items:
1. Im worried i bought a poor quality turbo, checked shaft play, prior to install and it had zero radial movement, and slight axial movement
2. called a turbo shop down here in Arizona and the guy said: "if it makes boost, your past the danger zone" he did sound very amused at my story tho. Guess not too many 2h land cruiser in these parts
3. Im still concerned about surge. Not sure if im making enough boost for that to be relevant or what, still fiddling with the BOV
4. Im not too concerned about the waste gate as i seem to struggle to get the unit to make boost vs too much boost, so a mechanism to back off the boost seems to be a non-issue at the moment.
5. After documenting all this, i think i left the boost hole open on the turbo when i ripped off the waste gate diaphram (oops!) better check on that later.
6. I still need to snap some photos to go with these numbers.
7. Im noticing more pronounced engine noise: (lifters, exhaust chuggs / charges, top end head noise) I suspect two things; a) manifold flip makes it so i can hear that better than b4. b) i need to retard the timing a bit as i may be hearing predetonation pinging?
Goals status:
1. help engine perform and not smoke at altitude. I drive in a very wide variety of altitudes (ACCEPTED)
2. Help engine tow my 1200lb mini-camper up to the mountains (PUlls 6% grade in 5th 1800rpm no trailer)
3. keep boost around 8-10 max (COMPLETE)
4. not blow up the engine (So far so good, too soon to tell)
5. not pay hardly anything for the upgrade. (price tag sitting at just under 600$ including wasted material)
6. BONUS Fuel economy went up from 16mpg to 18mpg I am attributing this to a more complete burn and more efficent combustion at 7000ft
more pics:
The goals are:
Results are:
Goals status:
more pics:
