Yes
It's called the Icon Stage 6
Front
Billet upper control arm
2.5 coilovers
2.5 piggyback front shocks with remote resi's and adjustable compression
S2 system for the piggyback which add another shock hoop and mounting location for the bottom of the shock on the existing lover control arm .
Rear
Billet upper and lower links
Adjustable track bar
2.5 shocks with remote resi's and adjustable compression
rear hydraulic bump stops
Both sway bars are gone and not needed. I really can adjust the roll right out of the system
I have been playing a bit with the compression settings. 1 being the softest
On the road without any thing loaded down, the 1 setting just makes it float over bumps. we have the rolling speed bumps, on my street that just get soaked up
I have an Odyssey battery up front that weighs about 85#. Winch bumper and 12,500 # winch along with a few lights
. On the trial , I will bump up the compression dampening a lot , but on the road it's almost a Deville
Here is a view of the left front
Rear bump stop and track bar
Rear lower links
rear upper link
Cortez visual. I have checked out some of their work . I think they will make a big impression
I'm going to do an entire write up on the process of getting this thing ready in a very short amount of time . I think my head is still spinning.
I will definitely represent. You guys are always supportive of my madness
thank you
P.S I just got a call from Cortez Visual. My 3/4 wrap is almost done . I will be picking it up today
