Thecriscokid
Supporting Vendor
Set to launch at Overland Expo May18-20
Here is a little preview after a couple days testing along the Kokopelli trail last week
http://www.expeditionportal.com/forum/attachment.php?attachmentid=96573&d=1334584336
Removable pop top conversion for 80 Series Land Cruisers (91-97)
Accessible through factory sunroof, aftermarket rear sunroof, roof cut away, and from the exterior of the tent.
4 solid rain gutter mounting clamps mounts the hinge top to the well over built Toyota Land Cruiser chassis
Designed to be a low profile camper option with little to no extra wind drag, Lighter, larger roof loads like longboards keep a low appearance help with drag.
Comparable fuel economy with Westfalia 2wd, Syncro, and 2wd Sportsmobiles with much higher offroad capabilities
Upper bed has similar dimensions to a Westfalia bed
Designed and constructed in Colorado using recyclable 1/8" Aluminum in a solar powered facility by the most talented craftsman.
Living rubber hinges are tested to 50,000 flexes and provide a weather tight front hinge
Estimated material weight of less than 120lbs without cushions
Outdura fabric on walls and cushions are soft to the touch and provide a mildew, rot and water resistant yet very quiet and comfortable sleeping area
Many options will be available:
Custom powder coating or color match paint finish
Custom Fabric colors and prints
Aircraft tie down tracks
Solar panels and both internal and externallighting
Official launch will be at Overland Expo May 18-20 in Flagstaff Arizona
Photo's from prototype V.1 on Kokopelli trail
http://www.expeditionportal.com/forum/attachment.php?attachmentid=96574&d=1334584456 http://www.expeditionportal.com/forum/attachment.php?attachmentid=96575&d=1334584457 http://www.expeditionportal.com/forum/attachment.php?attachmentid=96576&d=1334584458
