Hi there i am from Iceland, and I have a modified Land Crusier 80 1994. My father-inlaw owns the truck but I have him in my possession and I do most the maintenance.
I will post here the modification on the truck and future plans.
pleace be patience with my english, i´m not very good in spelling
one pic here. I will put the modification in soon. He´s on 44" Dick Chepek
*EDIT*
Truck:
Model 1994- Driven 240k- Leather- Original lockers- Automatic
Modification:
Body lift 4"
Spring lift 2"
Fender flares custom made in iceland
OME front springs
Original rear springs
Rear axel moved about 5" backwards
Original gear ratio in axel 4:10
Front mounted intercooler
3" exhaust
Extra disel tank fitted under the truck at the rear where the spare tire used to be. about 120liters and an electronic pump to pump in the original tank
Aircon modified to pump air
Custom front bumper(what do you guys call it), made of steinless A4. which is also a air tank
12000 pound Come UP winch, it´s fitted so I can take it of. I can fit it where the yellow hook is at the front in the picture below
12v/220v converter and 12v/19v inverter
Garmin 276c - Motorola GM360 VHF - Cobra CB and 10" laptop which I connect to the gps
*EDIT*
Here you can see the winch
*EDIT*
Future mods:
Lift the truck a little bit more and fit Mickey Thompson 46x19.5x16 Baja Claws
16" wheels with beadlock, 18" wide
New fender flares, longer and wider
New axel ratio 4:88
New front axel (custom made front axel which will be combined of original front axel and 60 cruiser rear axel, I want the 9" center)
New front axel Chromoly Birfield
Extra low gear(crawler box)
Paint job DONE
New lights with paint job. Front xeon, rear and turn ligths. DONE
Safari snorkel DONE
Custom home made drawer in the trunk. DONE
Custom home made roof rack (still designing it, I like the GOBI look) DONE
Custom home made rear tire mount (but instead of a tire I will have a box for my cable) and shovel, iron man and jack all 60" DONE
Bigger turbine (that blows about 16pounds) DONE
*EDIT*
Truck:
Modification:
Body lift 4"
Spring lift 2"
OME front springs
3" exhaust
*EDIT*
*EDIT*
Future mods:
New axel ratio 4:88
Paint job DONE
Safari snorkel DONE
