This thread is started in an attempt to separate old fan clutch questions from Landtank's Blue Fan Clutch thread which discusses and instructs how to set up the new part Toyota replacement fan clutch. For first timers to this thread, this is an attempt to discuss the possibility of revamping your OEM black hub or blue hub clutch, instead of replacing with the new blue Toyota replacement clutch. If you are having fan clutch related issues, browse through this thread to help you make a decision which route to go - revamp or replace with a new clutch.
Reference Landtank's thread for more info
This 1st question can probably best be answer by Kevin (Tools R Us). I could have PMd him, but I thought his experience on these fan clutches would best be shared amongst all of us.
I pulled my fan clutch to verify the type and condition due to my '94's mileage and also recent cooling system work that I've been doing. I've included a couple of pics. I started brushing off the dirt around the thermostat/spring and than thought, maybe before cleaning it up, I should ask about what looks to me to be a possible leak of fluid starting. The top-most fan mounting screw in the pics has an accumulation of greasy dirt. Is this an indication of a leak starting? The bearing appears to still be in excellent shape, at least by feel. I'm going to continue cleaning it up and remove the fan. I can include more pics if needed. Thanks for any light you can shed on this!
