fj80toyman
...One Landcruiser at a time
Recently got into the rear axle for some much needed service. Saw that a Special Service Tool (SST) was going to be required but I had the time so I tore it apart before buying said tool.
When I got in, I figured out a way to make my own SST to tighten the nut to it's spec of 43 ft-lbs during the bearing setting process. I'm sure others have climbed this mountain, but here's my take.
Here are some pics of the simple tool that replaces the OTC/Toyota SST in my toolbox.
First pic is after some quick work with a grinder to make the slots for the axle nut.
Second pic, part number of the "Great Neck" socket (p/n 336 25965). This socket says 66.5 mm x 80 mm and fits Ford and some Dodge products, available at Pep Boys and others for around $17.00. I think I probably voided the "Limited Lifetime Warranty".
Third pic shows how the new SST fits snugly onto the socket. After rough-cutting the three slots, I then ground away carefully at each slot to make sure I had a good fit, but also would move without binding on the nut.
End result, less than 20 minutes work, it worked well, saved me at least $25 if I bought the part from Toyota's tool supplier OTC, what with shipping and all that.
Oh, if you're the guy who needs to own the real deal, here's how to get it:
OTC Tools, SST Hotline: 1.800.933.8335
Website: www.toyota.spx.com
OTC SST Tool number 09509-25011
Quoted price: $37.82 not including shipping
Dan.
Anyone local needs to borrow this, let me know, I hope I don't have to use it for awhile.
Dan.
