LinkBack (21) Thread Tools Display Modes
Old 07-22-07, 05:34 PM   21 links from elsewhere to this Post. Click to view. #1 (permalink)
Bear80's Avatar
TLCA# 14779
Fan Clutch Service
Servicing the fan clutch seems to be nothing new for many. I picked up the idea after LandTank wrote up how to adjust the temperature for an 80series LC fan clutch (this is NOT possible on a Truck/22RE fan clutch).
The fan clutch problem steems from shearing the fluid over time, even just a 10yr period. At 20yrs, like most of our mini trucks, the fluid is pretty much doing nothing. Fresh silicon is the key! Just ensure there is no seeping of the fluid and that the rear bearing turns free without noise.
I've serviced four 22RE fan clutches this way with great results. Most noteably the A/C keeps blowing cold at idle and low speed 'wheeling. Previously when I'd be out creeping along in low gear, the A/C would only blow ambeint air untill I got moving again. Now I creep around in cool comfort! Not to mention I hear a slight roar when the clutch engages vs. nothing before, and there is noticeably more air being pulled across the radiator now.
Three of the clutches came off two '86 4x4 trucks, an '87 4Runner and the other off an '85 Celica. All of them appeare to be the same physically inside and out. However, each of the top covers have different numbers. Numbers on the oposing side of the spring mounts ranged from a 4k to 6F. While there is another number on the covers such as 10ck or 7ck. I'm not sure what these stand for. After doing some reading, it seems Toyota only used 3, 4 or 10k fluid regardless of market area. So then the 10ck and 4k could represent the fluid, however the numbers are in opposing areas and on opposing clutches.
I chose to use 6k fluid on my refills due to the hotter temps here in South Texas. I would guess that nothing less than 4k should be used and nothing more than 8k unless you're in 100+ areas like AZ. Then maybe 10k fluid might be open for consideration, but I wouldn't do a full fill of just 10k fluid. The fluid is mixable to make any range of weights, ie. 10ml of 6k with 10ml of 4k fuild will yeild 20ml of 5k.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
Old 07-22-07, 05:40 PM   #2 (permalink)
Bear80's Avatar
TLCA# 14779
Here is the fluid I used, it is R/C diff fluid and carried at any specialty hobby shop. The Toyota fluid is harder to come by (other than CruiserDan here on the forum) and been discussed to be under par of the R/C fluid. There is also other weights at the hobby shop and most are made in Japan.
-Benjamin-
Old 07-22-07, 05:46 PM   #3 (permalink)
Bear80's Avatar
TLCA# 14779
Be careful with the four phillips head screws. I recommend that the proper phillips driver be used, however a phillips #3 will work. I used my impact wrench to break the screws, otherwise it can be easy to round the heads when using a hand driver.
Also the rubber o-ring is NOT replaceable and must be reused! So take note.
Open and ready for a drain:
*this picture was taken after all the fluid was drained*
-Benjamin-
Old 07-22-07, 05:57 PM   #4 (permalink)
KLF
KLF's Avatar
Ineresting. Do you have any long-term results? I've read about doing this project in a few places, but never tried it. I do know that several people have tried it on the 3FE Yahoo list that I'm on, and it's never lasted. They always end up just getting a new clutch.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
Old 07-22-07, 06:05 PM   #5 (permalink)
Bear80's Avatar
TLCA# 14779
I've found that it takes about 48 hours to get all the fluid to drain out. It is some slow thick fluid. Putting it in the oven for an hour or so at 200* or "warm" will help speed things up. I drain it into an old pyrex tray, this also helps when I pour it out for measurment. Also I try to tip the bottom up and position one of the three disk holes at the bottom to help it drain. Then later I set it flat in the tray. I also highly recommend that anyone doing this measure how much fluid drained out.
After a good draining, they've all come to be right around 25ml and this is the amount I put back in. I've also found that a good way to judge if all the fluid has drained is to spin the clutch by hand. I left one to drain overnight and asumed all the fluid was out, but the clutch still spun with some resistance - pretty much how it felt before I drainded it. When all the fluid is drained the clutch will spin freely by hand and you should only feel the resistance of the bearing. This usally takes two full days or putting it in the oven for an hour or two will speed it up to just an overnight thing.
-Benjamin-
Old 07-22-07, 06:10 PM   #6 (permalink)
Bear80's Avatar
TLCA# 14779
Now for the fill. *Note* the o-ring is back into the top cover. It takes some patience to get the o-ring back into the grove so doing it before filling is best.
25ml of new 6K fluid:
Also there was discussion about how much to fill the clutch with, which is why I measured it. I know exactly how much came out and put that exact amount back in. I pour the new fluid into each of the three holes untill I see it flowing around the edges of the disk:
This will only get in about 15ml of fluid. For the rest I just pour it on top of the disk and then quickly put the clutch back together.
-Benjamin-
Old 07-22-07, 06:14 PM   #7 (permalink)
Bear80's Avatar
TLCA# 14779
Watch the screw heads when tightening the cover down. I use the same #3 phillips head from my impact wrench set on the end of a standard wrench. This way I can get it torqued tighter than with a hand driver.
-Benjamin-
Old 07-22-07, 06:17 PM   #8 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Good stuff Bear! FAQ'd
Old 07-22-07, 06:21 PM   #9 (permalink)
Bear80's Avatar
TLCA# 14779
Nothing more than a few months. I don't forsee how there could be any issues other than a bearing going bad. I've done my truck, my sister's truck and my dad's 4runner -- all doing fine and blowing cold A/C at idle. The other clutch was the first "test" unit and it also is doing fine. I plan to do this on my 80series.
-Benjamin-
Old 07-24-07, 04:48 PM   #10 (permalink)
Tools R Us's Avatar
If the clutch is in good condition, new fluid will restore it to like new performance or if you upgrade to a thicker fluid better than new performance. In the rust belt areas the thermostat spring can rust making the clutch junk, also inspect the bearing for play and look for leaks, ether will make it not worth refilling.
I have done many over the years with very good success. The early clutches from Toyota came empty and you ordered the fluid type that was needed for how hard the motor was operated. For most here we use 10,000 cst fluid and it makes a big airflow performance increase.
If the clutch that your refilling has little/no drive, then the fluid is shot, if you mix the new with bad fluid, it's life and performance will be reduced, so try to get all that you can out. Solvents aren't very effective on silicone fluids and can become trapped in some areas of the clutch, contaminating the new fluid, so the slow gravity, heat, wipe, compressed air blowing, etc methods are best.
IIRC on the mini clutch the "factory fill" is 2 tubes of fluid, 36 ml. Less fluid means that it's sheared more often, reducing fluid life. More fluid can be added, but it must all fit in the reservoir, or it will always be "on", never freewheel. If it's overfilled simply drain a little. My normal refill amount on the mini clutches is 40 ml.
If the clutch is good or new and you want to improve it's performance, simply adding thicker fluid to the factory fill works well. On the new 80 series clutches I add ~20 ml of 30,000 cst to the factory fill greatly increasing performance.
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 07-24-07, 05:21 PM   #11 (permalink)
Bear80's Avatar
TLCA# 14779
36ml really and a total of 40ml on a re-rill? I got out an average of 25ml pretty evenly from the four of mine. Think Toyota put too little in and adding more will help prevent excessive shearing?
Any input on the numbers molded into the top?
-Benjamin-
Old 07-24-07, 07:01 PM   #12 (permalink)
Tools R Us's Avatar
Toyota put in enough to work, I have found that adding more makes the fluid last longer. You drained and measured, good plan, but think about it. A ml. is very small, how many of them are still in the tray, on the utensils, soaked up in the rags, on your fingers, etc? I have tried measuring the drain a few times, it's sticky, thick, nasty stuff and it's hard to account for all of the fluid removed, so there has to be a "fudge" factor.
When the clutches came empty they came with 2 tubes, 18ml ea to fill them with, so that's the number that I use for the factory fill. Have seen some that looked like they had very little in them, so maybe the fill amount has changed over the years. I have put 3 tubes (54 ml) in them and only a couple of times had them stay "on" and had to drain a bit out, so settled on 40 ml for my fill amount on the mini clutches. It's just about imposable to get all of it out, so the number needs to be adjusted slightly depending on how good of a job you did on draining, cleaning.
The only drawback to adding more is a slightly longer fan roar at startup, takes slightly longer to pump the fluid into the reservoir.
They are manufacturing marks, probably for quality control, date, mold that it was made in, etc?
Old 07-24-07, 07:24 PM   #13 (permalink)
WristPin's Avatar
yeah, its very good stuff!
i was gonna FAQ submit this!
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 07-24-07, 08:07 PM   #14 (permalink)
Bear80's Avatar
TLCA# 14779
Always good stuf Kevin!
I agree with the slight fudge factor. I'd say in my draining measurments I lost 1-2ml. I was very careful not to be wasteful or slopy. With it being around 25ml each time I figured it was a good round number for Toyota to use. That makes sense for Toyota to supply the clutch empty and filled with your preference of weights in the past.
I think being meticulous with the measurments and factoring in a slight fudge factor will still yeild excellent results. However, Kevin is a great knowledge source and would take his recommendation about filling in the 36-40ml range.
-Benjamin-
Old 07-25-07, 08:48 PM   #15 (permalink)
LeftCoast's Avatar
Nice job. Thanks!
LeftCoast is offline   Reply With Quote
Old 08-04-07, 12:40 AM   #16 (permalink)
Anybody know if the 3.0L V6 fan clutch can be rebuilt and upgraded too?
www.ultimateyota.com | 93 4runner, 3.0, Auto, SAS, ARB, E-locker.
robinhood4x4 is offline   Reply With Quote
Old 08-04-07, 01:11 AM   #17 (permalink)
Bear80's Avatar
TLCA# 14779
yep comes apart just like above. I'd really suggest a good few days to drain. I've had one open for over a week and it's still got some comming out, like maybe an extra 1 or 2 ml.
-Benjamin-
Old 08-04-07, 12:28 PM   #18 (permalink)
Tools R Us's Avatar
All of the factory original and replacement Toyota clutches that I have seen can be refurbished and/or tuned. Some aftermarket clutches are riveted, swaged, etc, permanently together and most are poor quality, making them not worth your time.
Old 08-04-07, 01:27 PM   #19 (permalink)
Kevin, would you still recommend the 10k cst for the 3.0L here in phx?
Old 08-04-07, 01:59 PM   #20 (permalink)
Tools R Us's Avatar
Yes, depending on the fan type. If you have that exploding, POS ring type fan, replace it with a new non ring type before doing anything with the clutch.
Old 08-04-07, 02:04 PM   #21 (permalink)
Yup, that's the one I have and I was planning on replacing it as preventative maintenance.
Old 08-04-07, 04:53 PM   #22 (permalink)
what? i've never heard of that, how do you know if you have it or not?
the only way to get a j**p where a toyota goes, is on a trailer full of broken j**p parts behind the yota. its a HEEP thing.
84pickup is offline   Reply With Quote
Old 08-04-07, 06:42 PM   #23 (permalink)
Basically, over years of sitting in an oven that can vary from subzero temperatures to over 200 deg, the fan gets brittle or otherwise develops defects. Sooner or later it explodes, shredding the hoses, belts, battery and hood.
It's the plastic fan that has a molded in ring around it's outer circumference. If your fan blades look like normal fan like in your house, then you don't have to worry. You'll know it if you have it. I think only the 3.0L had them, not the 4cyl.
Old 08-07-07, 12:20 PM   #24 (permalink)
hmm my brother has a 95 4runner so i suppose i ought to tell him to do something about it. that definetely sounds no bueno. it's good to know should i ever get one. (probably never)
Old 08-10-07, 07:08 PM   #25 (permalink)
Bear80's Avatar
TLCA# 14779
I belive the ring fan was dropped with the addition of the front mounted electric pusher. I know my '94 didn't have a ring fan.
-Benjamin-
Old 08-10-07, 07:37 PM   #26 (permalink)
Tools R Us's Avatar
The later 3.slows had a normal fan, not sure of the change date. My '90 had an electric pusher and ring fan. TRD supplies the 3.slow ring fan in the FZJ80 supercharger kit, with all of the drama it has caused you would think that they wouldn't even sell them as a replacement!
Old 08-12-07, 05:18 PM   #27 (permalink)
I'm getting a lot of clicking at various RPMs from what I'm 99% sure is my fan, I'm wondering if that would be a bearing issue ? I'm thinking I should just grab another fan off a junkyard truck and toss it on.
Curse is offline   Reply With Quote
Old 08-12-07, 10:55 PM   #28 (permalink)
My 93 has an electric pusher for the AC and a ring fan.
Old 08-13-07, 01:11 AM   #29 (permalink)
P.S. Mine's an 86 22R
Old 08-17-07, 10:41 AM   #30 (permalink)
where do you get the o ring for a 22R fan clutch. anywhere or only from the stealership?
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/167678-fan-clutch-service.html
Posted By For Type Date
Indice: Giunto VS elettroventola This thread Refback 10-02-09 10:54 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 07-21-09 10:43 AM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 07-07-09 03:00 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 06-10-09 12:57 PM
Tech,FAQ,Tricks - Page 2 - DownUnder4x4 This thread Refback 06-10-09 01:03 AM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 03-29-09 12:12 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 02-23-09 10:57 AM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 09-06-08 08:22 AM
UltimateYota.com - Upgrading The Fan Clutch This thread Refback 06-03-08 04:52 PM
Upgrading The Fan Clutch This thread Refback 05-30-08 02:25 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-26-08 12:55 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-26-08 10:27 AM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-26-08 08:22 AM
UltimateYota.com - Upgrading The Fan Clutch This thread Refback 05-23-08 10:01 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-22-08 08:13 AM
UltimateYota.com - Upgrading The Fan Clutch This thread Refback 05-16-08 01:29 PM
UltimateYota.com - Upgrading The Fan Clutch This thread Refback 05-15-08 06:51 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-14-08 04:20 PM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-12-08 11:56 AM
ToyotaVanPeople.com • View topic - Another fan clutch question--ad-nauseum! This thread Refback 05-11-08 11:28 PM
UltimateYota.com - Upgrading The Fan Clutch This thread Refback 05-11-08 10:24 PM
