I've come to the point that many other lj78 owners have, cracked head that needs money thrown at it. So instead of the easy fix (new head), i've decided to go the long route. I bought a Hzj79 ( 2001 I think) ex mine truck, with a 1Hz and a 5 speed R151F tranny. The front clip was a little banged up, so I was able to source a complete front clip off of a bj74 in decent shape. The plan is to use the front clip from the bj74, and the engine/tranny and mounts from the hzj79.
Pulled the engine/tranny out of the lj78, fairly straight foward with the front clip off.
Got the engine tranny out of the hzj79, a lot less electrical, but the mine grime made the rust thick and abundant.
So now the easy part is done, first thing on my list is to deal with the front clip mounts. the 79 mounts are about 6 1/2" wider and a few inches foward. Not to sure if I want to cut the ones off of the hzj79( like to leave the front end attached), or just make some extensions and fit my lj78 mounts to it. The front cross member on the 79 is right inline with the mounts, where if I moved my 78 mounts out and foward they would be about 6 inches ahead of the 78s cross member. I guess what I'm trying to say is, do the mounts need the support of the crossmember right at the brackets?
Well I'm back off out side to tinker some more . Not to sure if I figured out the picture thing yet though?
Joel.
Joel.
