Decided to put one of these 140 amp models in after rebuilding the OEM unit three times.....not to knock the Nippondenso, but the 55 amps is a little low and the Mean Green seems a little overkill.
http://www.alternatorparts.com/CS-144_Special_offer.htm
It was shipped with an incorrect pulley (too narrow) that would fit if the alt was installed on the driver's side of the motor where the Smog Pump lives. Also, the two prong mounting base woulda worked well with the supplied spacer, if mounted in that location.
Seems to be a good fit for someone that doesn't need a smog pump anymore.
I had them send out a wider pulley and the adapter bracket shown in the pic.
Pretty easy to put on, but get a big bag of washers....
