Hi everyone!
I have a 1970 FJ40, 3 spd. All pretty much stock except for the 350 under the hood. The truck has become my Father-in-laws and I am posting up this question for him.
Anyhow, last week while doing some work to the truck, he noticed that the driver side the front wheel were not turning normally and binding pretty bad. He backed off the lug nuts and the wheel began to spin freely again. He took the wheel off and then just tightened the lugs directly to the drum, with no wheel, and it still binds when it gets tight. Puzzled, we placed washers behind the drum to space it out away from the hub, and it still binds when we tighten the lugs. I mean just hand tight with a small wrench not even using any kind of air anything, snug may be a better word.
I then took off the drum and put it on backwards on the lugs. The drum was not contacting the brake pads or backing plate. We tightened it up and it did spin free. I did notice that the drum looks a bit warped. Its not to bad but definitely not true.
Has anyone ever experienced this ? Brakes are all stock. A new master cylinder was installed last year and we replaced both wheel cylinders on the passenger side rear wheel, Bled the system and it was working fine until last week.
Truck is not a daily driver , mostly cuz my dad is retired. SO it can sit for weeks at a time.
Any advise or a point in the right direction would be great !
Thanks in advance for any advice or help with this situation.
Tony
Tony
