Looking to see what the difference between the years is. Got a lead on one and not sure of the year. If any body has some pics of the early 70's fan shrouds that would be great.
One "trick" I read on this board (and performed on my '74 F 1.5) is to split the fan shroud halfway up. This allows you to take it off without pulling the entire radiator.
I just made two small cuts through the sheet metal, and then made two little plates that reattached the halves of the shroud together to keep the vibrations down.
The bolts that hold the shroud to the radiator frame do most of the work of keeping the shroud in place.
It was a good mod.
Rocky
