SWEET! Let's see a wide profile shot of your rig.
2000UZJ, you're runnin' a lot of rake—are you going to crank those TB's?
That looks great. Really like the KM2s.
Do they rub? How close are they? I am driving a friends 80 with KM2's and they are great. This will be my next tire. Hopefully Santa is on mud and can read this. I have to decide between 305 and 285. Decisions, decisions!
How noisy are they? Say, in comparison to a BFG All Terrain? (I know they'll be louder, just how much?)
The new kicks look good! I ran those tires in a 35-12.50-17 on my 2008 Wangler and loved them on the street and trail. What side profile are your 305's ....65,70,75?
What is the max recommended pressure? I always run max pressure on the road. For my TG's I think it's around 44psi max IIRC, so I hover right around there.
Going from 35psi to 40 should help with the heat issue, but if you have room to inflate them more, I'd do it. Also, not that gas mileage is a huge concern with rigs like these, but airing them up to max does make a difference...every little bit helps.
airing to MAX cold pressure could easily put you to a point where only the center of the tread pattern is touching the road. you want a nice even contact patch for the best tire wear and handling.
