sleeoffroad
Supporting Vendor
Just FYI for people that use Warn 9.5 XP Winches with a feet forward mounting (like on some 100 Series bumpers). The motor has two drain slots 90 degrees from each other. The winch motor comes from the factory configured so it will drain when mounted feet down and the other drain hole is sealed with silicone. If you mount it feet forward, then the motor needs to be removed, the sealed drain hole opened and the other one sealed.
If you do not do this, then you will end up with a trashed motor if you get water in it.
