So my plans are this:
+ Strip all existing wiring.
+ Buy modular fuse panel from either American Autowire or Ron Francis ($$).
+ Use zip loom and run new wires throughout.
+ Open barrel terminals on everything. Give them a shot of solder after crimping, use heat shrink boot (I've grown quite proficient at this).
+ Try to defeat the terminals on either fender.
+ Hellroaring dual battery system. Welding wire cables. Mil-spec terminals.
+ Master disco?
What is the best type of wire to use? I've read the stuff in auto stores is junk and overpriced. Past experiences lead me to agree. I'm not sure where to get "good" auto wire.
Curious if anyone has worked with AAutowire products. I'm not too keen on using WAGO cage clamps. Snap spades seem a bit more secure.
What's a good alternative to using the exposed terminal blocks on either inner fender? I still want to be able to pull the fender and easily remove the fender mounted markers.
Also considering a break somewhere in the rear wiring (to avoid splicing in the future). Haven't been able to find a set of connectors that are weather resistant.
Where to buy mil-spec battery terminals and boots for them? If no boots avail, I'll just smother them in DE grease.
Thank you for your input.
Ian
+ Master disco?
Ian
