Where is the frame number located again?? I want to cut it out and weld it on the new frame as you suggested.
Thanks man!!! That was the easy part..the million dollar question will be can I get the edic to work starting my wiring from scratch? But that is a long way off.
you were right about the LHD vs RHD frame..not the same..doesn't mean I can't use it, just means I need to weld a bracket..not a big deal. They also don't have the rear spring gussets apparently, so I will have to source those someplace as well. Still a way better frame than mine..Where is the frame number located again?? I want to cut it out and weld it on the new frame as you suggested.
D
Oops! How did a pic of the wife make it in there??
.....- (Tom will probably later explain that technically they are not actually the same thing ). ....
... getting ready to drop the axles and begin rebuilding them..one last thing to come in in order to do that..some wheel studs from SOR.
