XFER Engagement
Santa Cruz
I don't think that my transfer case is engaging. Here is what I have so far:
Disconnected front drive shaft but still grinding.
N/N No Grind
R/N No Grind CDL Off.
From R/N to P/N I get a grinding noise but not in
P/N
________________________________________________
N/H No Grind
R/H Grind CDL Off.
R/H to P/H Grind
P/H No Grind
N/H No Grind
R/H Grind (can get reverse sometimes) CDL On.
P/H Grind
N/L No Grind
R/L No Grind, Vehicle moves in reverse fine.
D/L No Grind. Vehicle moves forward fine.
After several attempts of moving forward and reverse in Low range I finally got a grind in all applications, I have adjusted my shifter linkage and have eliminated the rear diff, so is it possible that my transfer case is not engaging?
Can you give more detail on the 'grind'? First impression is that something's wrong with your viscuous coupler. In low range your center differential is locked, and the VC doesn't activate... but on reading your post again I see you have the grind in low. More description please.
-Spike
Well, its hard to exlplane, but have you ever had a manual transmission with a lever type shifter for the 4x and tryed to put in into 4x LOW while rolling? Thats what it sounds like. The best I could explane it is like the transfercase is not quite connecting gears, and insteded of driving it just grinds. I havent taken the rear drive shaft off yet, but I pretty sure its not the rear diff. To test this I put it in N/N and was able to roll the truck by turning the driveshaft under the truck.
Disconnected front drive shaft...
Are you saying all the subsequent data is from AFTER you removed the front driveshaft??
You do NOT want the CDL off with one of the driveshafts removed, and you do NOT want to try to engage it in that case unless the tranny is in park.
Yes, after the driveshaft has been removed. And I have tryed all in the listed above. However had the same results before removal of the front drive shaft but I have a stripped Brif and Drive fllange, so I couldnt tell untill I removed the front DS.
N/L No Grind
See, that's good. The center diff. autaomatically locks in low, and that's exactly how an AWD vehicle with one driveshaft removed (front or rear) and the center diff. locked should behave. I.e., it drives just fine.
After several attempts of moving forward and reverse in Low range I finally got a grind in all applications...
Mmkay...,
Tha's no so good. :D
Again:
With a stripped flange and/or a driveshaft removed, the ONLY way the vehicle will move is with the center differential locked.
Yea, I was able to drive the truckin D/L and R/L without Front DS for a few feet and then in reverse for a few feet back and forth about ten times then it started grinding in R/L and D/L.:confused:
But why could I drive it ONLY on Low range and not when I engaged the CDL in H range?
I don't know I just got the rig. I didn't have a chance to drive it before I bought it cus it had a "busted transmissin" after I got it home I found the stripped drive flange and birf, now I am looking for other problems. I'm not having a hard time finding them too!
Just to make sure... is the transmission in P or N with the vehicle stopped before trying to shift from High to Low on the transfer case? These are not shift on the fly.
I may be a bit late on this but...
#1. With the center diff UNLOCKED, without positive drive to both axles (removed drive shaft or stripped drive flange) this vehicle will not move.
#2. With the xfer case in neutral, when you shift into any driven gear with the transmission shifter, the rotating bits inside the transfer case will rotate and will continue be driven with their own inertia when you shift into N. If the gears are still rotating and you shift into P, the parking pawl will grind.
#3. If the CDL LOCK light on the dash is not illuminated, then your center diff is NOT locked. The dash lamp is a tally from the actuator assembly on top of the transfer case. Or the bulb is burnt out.
At this point I have no idea what you're doing, but I would proceed with the following:
Remove BOTH driveshafts; transfer case in NEUTRAL (chock the wheels); turn the key to the ON position and push the CDL button on the dash. Phisically rotate both of the drive flanges on the transfer case by hand and see if the CD is locked. If it is locked, they will be locked together and be unable to rotate separately. If not, then you have found a problem and can proceed from there.
I'm sorry if I seem crass, but this thread and the first post makes little sense to me.
Yes the car is parked and not moving.
Ok Ill remove the rear DS and try locking up the CDL As you suggested. What I have listed above is the steps I went through to troubleshoot the system. I'm sorry if its not clear enough, I couldn't figure out another way to discribe what I'm doing. Also I My CLD light is working, I confirmed that when I put it in low range.
If the previous is unclear I will try to explane it a little. Here is the problem;
(with the front DS removed while parked) I cannot put the truck into gear without something grinding, I have succesfully put the truck in gear in Low range and WAS able to drive it for a few feet forward and reverse. In H range with the CDL locked I cannot get the truck to move, just grinding. When I put the transmission in gear without the CDL locked I don't get any grinding but I cannot drive it because of the obvious lack of a front DS.
Might be time to get another set of ears involved and localize where the grinding is coming from.
Have you checked fluid levels?
Some "Quick Lube" joints have been known to use ATF in the transfer case. Should be gear oil.
There is not a VC on FJ80s.
LOL, in my defense he hadn't identified the truck when I wrote my response.
Definitely sounds like something that should be investigated in person.
-Spike
Yup just did that I found some small bits, smaller than granes of sand, no chunks.
I confirmed that the diff lock is locking up for sure. Im concidering dropping the transfercase.
It sounds like the gears just wont engage when the transmission goes from park or nutral to drive or reverse. Im running out of Ideas.
:confused:
