XFER Engagement
Was the fluid that came out of the transfercase ATF or gear oil?
Transfer case should take about 1.5 quarts of fluid. If it was run dry then you may have an expensive problem. I suspect you would hear/feel that with a simple inspection.
BTW, have you checked the linkage from the shifter to the transfer case? You said it was like the transfer case was not engaging. I would have a looksee.
I checked the linkage first, the trans and the transfer.
I have a buddy thats a mechanic, he hasnt seen it yet but he said Im pretty much screwed. :frown:
I never had a chance to drive the vehical before I bought it cuz it had a bad PS birf and I guses all the grinding drowned out the sound of the transfercase.
Someone who says you're screwed without looking at the vehicle firsthand is not someone I would trust. If you bought the truck in sorry shape then you probably didn't pay a whole lot, so how screwed can you really be?
Stop messing around and put the truck on a lift and figure out what's wrong. Used driveline parts can be had from www.cruiserparts.net if you need them. Bolt on what you need and go.
Now would be a good time to get yourself a Toyota FSM and EWD. Anything you need will be in those 2 manuals.
Thanks jonheld. That's the plan, put it on a lift, and go from there. Oh and the advice was from a mechanic friend that I've fnown from high school! so no worries there. Ill keep you all posted on how this works out with pictures on my sierra cruiser thread. Thanks.
