Wrapping EGR pipe?
The resistor trick to disable the EGR is just a matter of unplugging the electrical connection for the temp sensor and plugging in a resistor. Once that's done the vacuum lines to the EGR can be blocked off and the EGR will never get hot again. The resistor is to trick the ECU that the EGR temperature is correct so that a check engine light doesn't come on. If EGR is later wanted or needed it can be reversed in a matter of minutes.
The resistor is a 4.7 K-Ohm, available in a 5 pack from radio shack (part # 2711330).
When you say block off the vacuum lines, I am still unclear which ones (...I know. And I've read everything. I need it Barnie style.)
1 or 2 or both or neither?
I added blue circles where I blocked mine off. The idea is to stop any vacuum from reaching the EGR valve so that it stays closed. The EGR valve amd modulator can stay in place it just wont be doing anything.
What did you use for blocking?
Mine are currently blocked the ghetto way (zip tied the vacuum hose into a pinch) but when I stop by the parts store I'll pick up some vacuum hose caps.
I use the Toyota vac plugs they last years there on the 4 runner v6. You can plug off the throttle body hoses that attach to their there on the throttle body
The plug on the valve cover in my pic is the factory resistor only on 93 harness. Take the restior an run it in series with the two gray wires one wire to each end of restior. The wire your cutting is the temp signal I believe which gives a restiance value when working. I would roisin core solder both ends to restior followed by dipping end jb weld or epoxy you can use a acrylic hose cut down the middle as a mold an tape off your ends an remove tape to finish off a nice look .Zack r came clean on the part nuends. The epoxy will cover an protect vibration an elments
You can use the simple plug in off the 93 harness. but not being mean good luck finding it. It has a restiotor n plug I still Redmond the the block off plate an BOTH gaskets r important I have block off plates top an bottom on egr
I bent the ends of the resistor and plugged it into the harness, then sealed it up with electrical tape. Be careful when bending the ends since they can break (having the radio shack 5 pack is handy in case you break one). No cutting of the harness needed. It doesn't matter which end of the resistor goes where since its just closing the loop.
A temperature sensor (like the EGR one) is just another type of resistor that the resistance changes depending on temperature. With the resistor in place the system is "seeing" a temperature that is within the expected range.
Irregardless of the resistor method make sure to secure the harness so that it doesn't touch the EGR pipe. As long as you have some clearance and the wires are safely within a loom they wont burn up. The point of the resistor method is to further protect the wires by not allowing the EGR pipe a chance to get hot in the first place.
OK, I think I get it. So if I wanted to just pull all the EGR stuff and block the ports, I could just do the resistor in the plug that is left?
Don't wrap the EGR plumbing.
The purpose of EGR is to inject an anoxic charge of air into the combustion chamber to lower the peak combustion temps to minimize the formation of NOx.
The dirty workaround which internal combustion engine engineers discovered long ago was to simply suck in some exhaust to dilute the % of oxygen going into the engine.
The ideal EGR gas would be 85° pure nitrogen. An unburnable dilutant. But since we can't carry bottles of that around, we're stuck with filthy blazing hot exhaust.
Older vehicles and the newest vehicles have EGR coolers, whose purpose is obvious. The most recent high horsepower engines have water cooled EGR coolers.
EGR gas is the same temp as EGT. And in a gasoline engine that can easily go above 1000° when pushing it.
Nothing good comes from injecting 1000° exhaust back into the A/F mixture. As far as EGR temps are concerned, the lower, the better.
On the cats dont hack the pipes u can get the flanges an weld a pipe too save your cats. Yeah I have both block off plates but bolt mine for visual
you can block off pair also but you need cable mount off 95 to 97 or just leave pair on or slide a plate between air tube sand which style
OK, this is pretty convincing. I think after all of this I am just going to re-install it the way it was and forget about it until it causes a problem. Hopefully wrapping the wiring harness will eliminate that possible problem source.
Thanks!
Correct, the plug you are adding the resistor to is on the harness side.
So I did this last night. Kinked and zip-tied and capped three hoses and tried to do the plug. On my '97 the side going to the harness (not sensor) is the male side of the plug so I can't really insert the resistor. I tried bending the connectors to make a little room to hold them there then I put heat shrink around them to keep from touching each other, then taped the whole thing and zip-tied it to a line on the brake booster. Started fine, drove fine. Then today I'm driving to Clackamas to visit a supplier and the CEL comes on. Think it's that resistor?
On my 94' the harness side is female so it was easy to plug in the resistor, but i could see how it would be almost impossible with the male end. For it to last you'll need to cut the wire and splice in the resistor. If it were me I'd cut on the EGR side and use the factory plug so that the harness isn't cut. Not as easy to switch back but still doable.
Hopefully someone with a 95-97 can chime in.
This makes sense. BUT I still stand by my decision to wrap the pipe and here's why.
  • It's about a foot long and has no cooling fins so it certainly wasn't designed to shed heat effectively (at least that wasn't a concern)
  • The amount of cooling the pipe could even give is insignificant and possibly immeasurable due to the short run and the high velocity of the exhaust running through it.
  • The number of people having problems from melted wires due to a hot egr pipe is massive. I have not heard any issues with hot egr temps.
This is also a good way of thinking about it. Hmm, not sure what to do...
I know I don't want to melt my wiring harness, that much is set in stone. Especially since ordering a new wiring harness is no longer an option. I really don't care if the EGR works or not, but I also don't really feel the need to disable it because it seems to work just fine and there may come a day when testing in my area comes around.
I still may wrap the pipe and then monitor the whole thing for a bit. All of these ideas are going to be easier now than they will when I put it all back together next weekend.
How long have you had yours wrapped? Have you noticed anything different since you did it?
