GM Work Truck Build
General Motors, Chevorlet, Pontiac, Oldsmobile, Saturn
Bought a 2000 silverado. 3/4 ton 6.0 truck 2wd. It used to be a county truck. I suspect the 4l80e is newer. Has iron heads. Cats are cut out. Drove it 30 miles from where I got it, runs surprisingly well. Need to give it a good look over before I really drive it any further. Just going to document my some basic baselining. Follow along if interested...
Bought a 2000 silverado. 3/4 ton 6.0 truck 2wd. It used to be a county truck. I suspect the 4l80e is newer. Has iron heads. Cats are cut out. Drove it 30 miles from where I got it, runs surprisingly well. Need to give it a good look over before I really drive it any further. Just going to document my some basic baselining. Follow along if interested...View attachment 3113361
Why would you buy such a thing unless you fully intend to use it as a donor for the 6.0 to a Land Cruiser?!?!?!?!?!?
I needed a work truck that could tow a fair amount if needed.
How many miles? I forgot about the iron head 6.0s
230k. Yeah the iron heads have no head number on the corner I just learned
what did you pay? No reason to drive a rusty chevy in the southeast unless it was under $1500
Next cheapest 6.0 truck I could find was 1200 more than this one and about 500 miles away. Seems like prices have gone up, I've been keeping an eye out.
Holy crap! That could pass for something from the 70s
Rockers are OK? Those are bad about rotting out on those trucks.
Rest of the cab is OK. Once I'm in a position to fabricate again I can fix a lot more of the cosmetic issues. Although I kind of want to limit how far I go with it. The dash isn't cracked which is nice.
Got the exhaust fixed. Only real immediate need is a radiator. It's leaking a bit. I'm thinking of getting a Chinese aluminum radiator...
I really don't like plastic radiators that much and avoid them if I can. I'm going to see if I can find anyone on the forums using these radiators. The original clutch fan works great, its like only the original with truck clutch fans on gm stuff works right i guess. The power steering box will need rebuilt eventually due to seeping as well as the hydroboost will need new seals at some point. I'm injured, so I'm pretty limited on what I do. I'll get a shop to do a radiator and perhaps some shocks and everything should be good for a while until things settle down. Overall I'm happy with the truck. The floor rust was a definite unexpected issue but not too bad of a fix.
I ended up replacing the radiator with a denso unit. Works great. I need to replace the driver door pins and ultimately the door. Used doors are cheap and plentiful. I replaced the broken stalk switch with a used one. Replaced the cracked washer tank with a used one as well. I also washed the engine compartment. A old trailer controller came with the truck. Replaced the trailer plug and it works. I also got a set of aluminum 317 heads I can port if I feel bored. I also used a cheap heavy duty door mat from home depot as a floor mat. All the cheap floor mats are too cheesy. Im getting 12 to 13 mpg city so far.
This truck has been working great for me. It always starts. Super reliable. However I found a cheap 4x4 HD truck with a 6.0. Having a beater pickup is awesome. Here is the replacement:
It needs tons of little odds and ends. But the 4x4 works, it runs well, and looks pretty good I think too! The exhaust is turned down at the back of the cab, so it's loud and drones horribly.
So I found a 3.5" factory exhaust and installed it. It's whisper quiet now.
Found a rare cluster that I liked. I soldered in new gauge motors and added custom lighting. It's from a 2500 avalanche. The old duramax cluster someone installed worked ok, but the cluster was incorrect. Also installed a new cluster lens. Old:
New:
are you still in Savanah?
Got a new to me trailer. It has two 6000lb axles. Need to replace the coupler though, it's only rated for 7000lbs. I also need to figure out what I'm going to coat the boards with. Some more tie downs are needed on the rear half. My trailer brake controller had no power. Had to replace the two large fuses on the top left and right. 30a and 40a.
I've had a knock sensor code since I got the truck. Its a common issue at higher mileage. So...
Code is gone. One less thing to worry about. Still have a srs light on. Waiting on parts for that. I had a bad headliner in this truck, so I pulled it down and recovered it.
Im adding a winch to my trailer. So I added wiring that goes to the back of the truck. Its somewhat installed so it can be easily removed to add to a different truck if I get a different truck. The 6.0 has been reliable, but you have to work to keep it in the powerband uphill. I got these battery lug adapters to ease adding the cables.
