"Woody" Rear Panels and Speaker Install
Hey all,
Just want to share my latest project on the Land Cruiser. I wanted to replace the rotten/warped MDF panels in the cargo area (I have gaping holes in my quarter panels so they'be been exposed to quite a bit of snow and rain). Also, many of the plastic pieces that attach them had broken so I wanted a better way to attach them.
Anyway, here's what I ended up with. I'll let the pictures do most of the explaining.
1/4" plywood with deckstain. With the plywood being much more rigid than what I replaced, I took the opportunity to add a 6" speaker and tweeter in the rear.
Here's the panel cut out of 1/4" plywood. I simply traced the shape from the old panel and cut it out with a jig saw.
The speakers I chose are Rockford Fosgate R165-S. They provide cutout templates on their website which are very helpful.
Testing out that the speakers will fit without needing to cut or relocate any existing braces.
Test fit, everything looks good.
I had concerns about mounting the speakers on only 1/4" of plywood. So to add a little strength, I added another 1/4" ring of plywood to the back side of the panel.
Wiring the new speakers was very easy. Just follow the wiring channel that already exists for the tail lights. I had already set up a new stereo that supports rear speakers, check out my thread about that install for reference. I used marine disconnects from Amazon to make removal of the panel easier.
I went through a few options on how to mount these. I like the idea of rivet nuts, they're a solid permanent solution but I don't have the right tool to install them. There are ways to do this without that tool but it turned out to be a pain in the a** (maybe I just need more practice?) The bolts are then inserted from the back which gives you an easy way to line up and install the panel.
To save me some time and energy, I ended up picking up a lot of these "quick nuts" from Ace Hardware. VERY easy to install and honestly, probably just as secure. I still have enough rivet nuts to replace these, which I'll do once I muster up the energy to open this project back up.
Twelve bolts later, the panel is ready for attachment. You can see the mix of rivet nuts and quick nuts in this pic.
Ta-daaa! Add some recessed, stainless steel washers and acorn nuts and we're done!
I just reused the hardware from the original panels for the washer fluid cap.
Someday I'll have someone reupholster these panels to match the originals. But for now, I can live with the "woody" look.
Well done! I like the wood too. I used 1/8" mahogany in mine, havent' had time to put in my newly acquired
nutserts yet. I got a nutsert tool at Princess Auto up here in Canada, don't know what your options are but it
was only $54 including nutserts. I like the woodgrain, no need to cover it up.
Thanks! Yeah, every tool I looked at was around $40-50 bucks (without the rivet nuts). Which just seemed to be a bit much for this project. Maybe if I find more projects to use it with. I'd love to see pics of yours if you have them.
Nicely done. Looks great, you've got a skilled hand at the jig saw. My cuts tend to look like they were made by a drunk on a unicycle.
Thanks everyone!
Now we just need to get those "gaping holes in the quarter panel" fixed....
Tell me about it. I feel like I keep taking on little projects like this to distract me from the sticker shock of what that'll cost. Maybe I need to learn to weld...
