Won't start after plenum removal
Alrighty so I have a 94 fj80 that's new to me. So basically I was finishing up a pair removal and after I put the plenum back on and hooked everything back up and went to start it up it would not start. I got it to start once By feathering the pedal while still cranking on it but I killed it because it would not run smoothly at all.
After I turned it off I messed with a few things and still won't start. It ran perfectly before this except for code 25 which it has had for months.
Things I did while doing the pair removal
Replaced fuel filter
Left all vac lines on underside of plenum. I just unbolted the pair valve on the pass side and plugged vac line.
I want to make sure it will pass inspection before taking all vac lines off under side of plenum.
I have fuel and spark.
Smell like gas out the tail pipe while trying to start it now even with spark.
I am very mechanically inclined but figure mud would know some things I don't.
Any help is appreciated
What is plenum?
The plenum/intake rubber doohickey is known to crack in the ribs and really hard to tell if so, BUT causes what you mentioned. Engine running "rev" or "flex" the pipe and see if changes, or spray some go juice around it and if if it jumps up.
(They become brittle over the years, and if you remove often cracks them)
Stupid iPad. Posting on here with it is tricky.
I checked all the basic stuff. I am a ASE diesel and gas technician I'm still young though and I'm just not used to obd 1. And this is weird. No problems whatsoever before this so I'm hoping for some help from y'all fj80 gurus. Since I got code 43 is it possible that I effed up the cam sensor on the dizzy
I checked the module it looks good. I did have a hell of a time with the fuel filter. I had to disconnect the fuel line next to it.
I may have tapped it with a wrench a few times but not hard or anything like that. Knock sensors are plugged in. At first I didn't have any codes. I wonder if they appeared when I ran the battery down while cranking. They appeared later after I did run battery down. Code 12 in my FsM says no rpm signal. 43 is starter signal. do have spark and fuel.
Alright guys I finally figured it out this morn. I had vapor lock in the fuel line from the fuel filter to the fuel rail. I cracked that line on the rail and tried to start it till I saw fuel come out then tightened it and then she fired right up. Crazy haven't had that happen on a gas engine before
Thanks for the help. Hope this helps others in the future
