Build Won a '74 40 on a coin toss...
I was in Vegas this week for a big insurance and risk management conference. We had dinner with one of our larger customers one night. First time meeting them, I was introduced to the future controller and before we even got in the restaurant, somehow he shared he had a '77 FJ40 that he wanted to get running again. I think his father-in-law or his grandfather is the original owner. Talk about a small world. We proceeded to talk Cruisers for a couple hours... He lives up in Rocklin, shared with him @Racer65's site as well as another person who I had bought a body panel from.
IRMI?
I'm with Amwins. Sounds like the making of a super nerdy insurance fj40 club!
Okay got the plate bracket installed - now just need plate to arrive. My bumper is much narrower than stock so I tried to have it line up flush with front of bumper. Not much more I could do. And how in the world did I just discover the spring loaded center punch? That thing is awesome (simple pleasures in life lol).
Decided to shake the cobwebs off and go out for a spin. Tires needed major air and I had to fill carb with fuel to start it since it had been sitting so long. But like the tractors these are drove like a champ on my little backroad loop.
Tried the horn just to see if anything fixed itself but no luck 😂.
Man, problem with taking a long break from the cruiser is I don’t know what I have and where a lot of the stuff is! Decided to give a fresh shot at the horn issue and got the steering wheel all apart but now can’t find my puller… I used to get a click at the relay now I get nothing. Yay.
So also discovered a tool I bought to help free up stuck screws - worked great on the windshield hinge screws! But I can’t find the replacement screws I’m almost certain I bought…
Guess I have some Black Friday shopping to do for replacement screws… ;)
Re your horn problem: this thread of my horn adventure may be of some help in yours
I will check it out thank you!!!
For what it is worth, I have never needed a puller to remove a cruiser steering wheel. Remove the nut, sit in the driver's seat then grab the wheel at the 9 and 3 o'clock position. Pull hard/rock it back and forth gently and it should pop off it's taper. Big ol steering wheel provides a lot of leverage and I have had success on 3 separate vehicles this way without ever damaging them. Good luck!
Okay, I think I have this horn situation figured out! Keep fingers crossed! Too late to test it though. But I decided to be more methodical this time (and not so ANGRY!) and I tested for continuity in all the wires that feed the relay and then found the wire that supplies the voltage to the relay. Here is what has thrown me off - there is a GR wire coming off the steering wheel horn buttons. I checked that wire again for continuity, which runs in a harness down the steering column to just under the dash and all good. Then I pulled apart the connector and there is no mating GR wire. The GR wire at the relay is hot so must run to fuse box (schematic shows a horn fuse but mine doesn't show "horn" at the fuse box). The GR wire from the steering wheel connects to a GY wire which goes to relay.
Steering wheel GR -> connector GY -> relay GY
So I have wires all messed up on the relay:
GW GY
GR
Should be:
GR GW
GY
It appears based on the schematic that the HBS on the relay is H=HORN, B=BATTERY, S=SWITCH. Makes total sense. I looked at an old post of mine and I had bad info:
Correct:
Incorrect:
Please let there be a god... 🤞
Does the horn in your 75 work? (hint hint)
Ordered a 12V testing device to help with this and future electrical issues. Think I saw it on @wngrog ‘s amazing builds.
In the meantime, anyone now what this capped GW wire is coming off horn harness?
Dang that tester is awesome! I got the knock off version (https://www.amazon.com/dp/B071LHLSBB?tag=ihco-20), about 1/2 the price. I determined the following tonight:
  1. Steering wheel shaft is properly grounded!
  2. The lone horn I have hooked up is properly grounded and there is continuity between the harness at the relay and the wire plugged to horn
  3. Other horn - nothing. I checked to see if the cut off GW wire under the dash ran to the other horn (also GW wire) but nothing there. I could probably just wire up two horns on the same working wire. Of course at this time, I'd take even one horn working lol.
  4. Relay appears to be shot - grounded the S tab and put 12V on the B tab, no clickety-click!
Time to order a new relay!
