Im driving it, but I want 7lbs of boost.....she is beautiful, but she is a bit overweight. At 8,200lbs I need al the boost I can get.
That is not how this kit works, there is no boost controller. There will be a difference in boost between cold and dense air in the winter and hot and thin air in the summer. Boost is a function of overcoming spring pressure with backpressure and atmospheric pressure.Im driving it, but I want 7lbs of boost.....she is beautiful, but she is a bit overweight. At 8,200lbs I need al the boost I can get.
Not correct the spring will open when backpressure passes the spring pressure that is why when you pinch it off it is only 4-5.5psi. You are not clamping the wastegate closed, so you should not see boost instantly go up and past 7psi. You can swap in a stiffer spring if you are willing to watch the AFR's and knock closely.I realize there is no boost controller, thus the spring is essentially it. There is certainly an issue at hand. By clamping off the waste gate hose and rallying it, the boost should instantly go up and past the 7lbs mark, not bleed off and dissipate. This is the clue that something isnt right
No it wouldn't it would still change with the seasons, you could dial it up in the summer and down in the winter. But 1 psi is going to be about 9hp, so it is up to you if the risk of messing with it is worth it.ok, if its a spring stiffness issue, wouldn't it be more simple to purchase one of those dials I splice in the middle of the waste gate hose... this would ensure a perfect dialing in of 7lbs correct?
Yeah on this system ideally you could use a stand alone system to control, boost, timing, and fueling but that’s an added a level of complexity and cost that we didn’t think most people would want. It would almost double the cost of the system once you add dyno tuning time, wiring, etc.Ok, I understand now. Thank you. I’m used to a piggy back system on turbos regulating things. It makes sense that this is a safety built in for different temps.. I’ll just drive it.
To be fair, this is your own fault. You could be suffering endlessly right along with me. But no, you chose peace and serenity.And sorry I say “WE” but I do not sell, profit or invest in this kit. It’s all Joey @NLXTACY at Witt’s End that made it happen. I just provided some information after setting up my turbo.
It’s a good question. Yes I am.Probably a dumb question, are you running premium?
