ARCHIVE Wits' End Anderson SB50 PowerPole Custom Mounts
Very nice!
How do you disconnect the air hose if you can't reach the "barrel" of the air chuck? :confused:
I want a couple of those, but with Andersons big enough for jumper cables.
The front face of the disconnect is now flush with the bracket. When I took the pics I didn't have the threading all the way tightened.
Jumper cables will need the SB175 version.
@NLXTACY Nice setup on the air coupler, as i've seen on fb. what couplings do you use to go from plastic line to coupler? Maybe you should hook me up. Installing OBA soon, but i'm hesitating to use "plastic" lines here in the cold winter. What do you think about that? I'm usually just running a rubber line. But it would definately be neater to use push-fittings from compressor-tank-outlets.
Give me a little bit to do some research. I chose Nylon 11 specifically for heat/cold but Norway may be a different animal.
Yo! My family is all Norwegian! I'll look you up in October when my daughter and I go to Norway!
