ARCHIVE Wits' End Anderson SB50 PowerPole Custom Mounts
About to go into production with these. Just a quick question, raw stainless or black powder coat?
Powder coated 'plywood colour' ?
Whatever colour you choose will be wrong, so keep life simple and let the purchaser paint it if they want...
cheers,
george.
I would like it in stainless, anything I have that's powder coated is got some amount of rust on it. Gotta love the rust belt, cool product BTW, I'm in.
Was asked by a handful of folks so far about the Edgestar, had no idea they were so popular. I just ordered up a bunch of polarized plug ends but had some paying around so put one together. I've now added this plug and the kit to the site as well.
Anderson SB50 DC Power Cable for Edgestar
[URL='http://absolute-wits-end.com/anderson-sb50-edgestar-fridge-to-battery-complete-wiring-kit/']Anderson SB50 EdgeStar Fridge to Battery Complete Wiring Kit[/URL]
[URL='http://absolute-wits-end.com/anderson-sb50-edgestar-fridge-to-battery-complete-wiring-kit/'] [/URL]
Thanks, I'm still unclear on using the big Anderson plug for 16 ga. wire. Do you just fill the space with solder? For 16 ga. I used the smaller Anderson power plugs. Just wondering if I did it wrong. I like the idea of a heavier plug, didn't know you could do that.
I'm not a fan of the little power poles. I know they use the same locking type terminals but it just feels chinsy. I like the SB50's size, amp rating and wire size range. Anderson makes smaller wire terminals and they also make inserts for smaller wire sizes. Depending on the application I use one or the other. I fill the terminal cup part way with solder, I tin the wire and then insert the wire into the solder "filled" terminal cup. The wire is NOT coming out. What I have not discussed yet is how I am taking care of strain relief. The coil wire is ROBUST so a lot of fridge pulls would eventually put strain on those 16awg wires. So a strain relief is needed. I'm still testing a few options but I intend on having a solution as part of the kit. I wish I had a 3D printer because then I would know EXACTLY what I wanted. But this won't stop the product from going out because not every application is affected. So once I decide on a solution then I will just send those out to everyone that has already purchased. Hope that helps?
Did a customer install today to test things out. A couple of interesting takeaways:
• Works great, thankfully
• Even without doing the flush mount install it still came out clean
• Where the SB50 plugs in can be critical because the coil itself can prevent the slide from closing BUT at least it won't damage the coil
• Its helpful to have something on the fridge side to keep the coil from wanting to pull the plug out of the fridge. Not that I think it would but who knows. In the pics the plug goes under the fridge cover which acts as a cable retention device. Works great.
Something I wanted to make sure people could see for those looking to use the flush mount version. Now you can make it flat mount but doing a few cuts but you could also make it truly flush mount by also trimming the material a little. Obviously you can't make metal flush mount (maybe thick aluminum) but would work really nicely on wood.
To make it flat mount:
sb50-cutting-template-a-jpg.1232710
To make it flush mount do this in ADDITION to the one above:
sb50-cutting-template-b-jpg.1232711
