Wiring through the headliner
Arizona
Has anyone have a good trick to fish wires through the headliner? I am installing a overhead console for the sub-tank and I have 3 different fishes and none of them work. I can not figure out how to remove the headliner enough to work with because it is not in my FSM (or least what I seen).
Any ideas? Any nice tricks? Looking for the easy button to make it easier for me!!! :confused:
Tony
Well for my '96, you have to unscrew all ot the grab handle screws. Well all except the passenger side A-pillar grab handle screws. Remove the felt trim around the sunroof opening and the rubber trim at the rear hatch. At this point the headliner will be able slide out after undoing the upper pilar mounts. Just slide the whole thing out the back.
Take a bicycle derailier or brake cable and fish down the A-pillar. [It's stiff enough yet small enough to fit the tight space in there. Now remove the wires to your overhead console from the wiring plug, electrical tape the tips then tape to cable. Pull through and replace wires in harness (take a picture of them before you remove). I just did it last week.
Sorry, I have a 93
Tony
I will be a :ban: :ban: :ban: :ban:
I can not see a way to get this thing off. I should have looked at this before I got all the things for an overhead console for my sub tank.
Tony
Depending on the wire, a small wire will simply go up an A pillar hidden behind the rubber windshield trip lip, then across the top of the w/s same way. Pull the mirror mount from there.
DougM
Well I have everything ripped apart and tried and tried to fish the wires through. Each time I get to the point of the A pillar where it curves, aparently the rubber from the wire gets caught in the groove and it will not budge. I have tried to ease it back and forth but that is not successful. I tried getting tough with it and I break the wire. :doh: :bang: :doh: :bang:
I am pulling from the top in from the bottom because the longest wire will go back to the tank. It is not desired to go from top to bottom but I tried that any way and it still gets caught in that one area.
It is like I need something to fill in that V groove so the wires can pull through easier but I can not figure it out. I spent 3 hours last night screwing with that thing. :bang: :bang: :bang:
Tony
I know, waaay over due but I got the wires in and everything is hooked up and working as advertised. This was one of several projects I was doing at one time. Here are a few pics
I wish I had pics of that "dirty, greasy silver console" before I painted it. It was nasty!!!
Tony
Tony, I am working with a friend to get the sub tank console wires up through the A pillar. What magic touch did you use to make this happen if you don't mind sharing? I don't want to tear out the headliner or A pillar liner either and am hoping you figured out how to use a fish tape to get the wires safely up the A pillar without issue?
Thanks in advance for any help, direction and photos.
Bump...
Anyone know???
Hi Tony, when putting in my overhead console I found it easier to go up the LEFT hand pillar, away from the fuse box (RHD), so for your left hooker, try the RIGHT hand pillar, there seems to be less cables there.
regards
Dave
