RW= Red/White stripe
G = soid Green
GY = Green/Yellow stripe
GO = Green/Orange
WB = White/Black stripe(always ground)
All side marker lights will have one +12v wire to each light assembly. The assemblies will have a WB(white/black stripe) ground wire that needs bare metal contact under a mounting screw.
Driver & passenger Front side apron markers are RW
Driver & passenger Rear side apron marker “I think” are both G
Passenger front turn/marker has a RW and GY. In case your harness is hacked, The front fender mounted marker RW wire meets with the side apron marker RW approximately 7” from where the horn relay branches off.
Driver front turn/marker has a RW and a GO
Make sure you scuff the bullets, bulb bases, bulb sockets. The front fender mounted turn/marker housing only works when you tighten the mounting stud nut against a patch of bare fender metal
. You must also ensure one of the 4 bolts that attach the fender braces to the frame in contact with bare metal(ground path)
When you go to hook up the wiper motor ask me for a link or search coolermans website for the “Backasswords” sub harness connection instructions
Do you have a fusible link? If not you’d better get one. Coolerman sells some.
A word of advice given to me by the legendary Coolerman: make sure the two WB’s at the voltage regulator are clean grounds. They are critical because they ground your entire harness.
All three versions (that I have) of the 71 wire schematic have some slight wire color errors.
