Vacuum Switching Valve test
Probably useless info, but I ran a test on a 71 VSV and figured I'd post up in case someone might someday be doing a resto that includes retaining the OEM Nippondenso VSV.
To power up the VSV I ran +12v to the horizontal tab and ground to the top vertical tab.
Here are my test observations:
With +12v
#1 holds vac when #2 is plugged
No juice
#1 needs main plugged to hold vac
With +12v
#2 needs #1 plugged to hold vac
No juice
#2 needs #3 & #4 plugged to hold vac
With +12v
#3 needs main & #4 plugged to hold vac
No juice
#3 needs #2 & #4 plugged to hold vac
With +12v
#4 needs main & #3 plugged to hold vac
No juice
#4 needs #2 & #3 plugged to hold vac
With +12v
Main needs #3 & #4 plugged to hold vac
No juice
Main will pull a bit of vac with just #1 plugged but also needs #2,#3 & #4 plugged to maximum vac
Guessing this VSV is still good but I've never ran across testing procedures to verify.
