You may be able to wiggle the tail enough to fatigue it and snap it off.I called my dealer and asked where they have glass done - specifically for the 100 Series. The service guy recommended the place they take any cars that come in and they already knew the deal with all the rivets etc.
On an unrelated note, on my 06, I lifted up the thin rubber strip and found this. What's the easiest way to cut the little tail off the rivet? All the others are fine
I will need to do that if I ever need to replace a windshield. There is no way a local glass shop will get it right. However, there is a guy in Dallas (6 hour drive) that knows what he is doing.The other option is to ask them to install the glass then handle all the trim work yourself. As crazy as it sounds, I'd be very tempted to go this route especially if they're installing it at my house. It would take me 3x as long but at least I'd know how it was all put together.
Could you PM me too? I am in NE Cobb.I have a local guy. I'll shoot you a PM.
I think you'll need 4 per side. To keep things interesting, @HoustonFj80 used Toyota PN: 90269-06013.
Sizes per his notes:
90269-04053 factory rivets (3.2mm)
90269-06013 (4.8mm)
90269-05034 (4.9mm) (size per measurements found on a Russian website)
75547-51021 (???mm)
My old thread that evolved into a conversation about rivets.
Couldn't take it any longer, it was time to take a look under my windshield trim
I bought my LC almost two years ago knowing the windshield had been replaced. Since I brought it home, the wind noise hasn't been excessive and there is no indication that water is leaking in through the a-pillar (though it's garaged while I'm home and at work). That said, the molding that...forum.ih8mud.com
Solid tech, thanks for adding this.Part number 90269-05034 comes in at 4.8/4.9mm (and 18mm in length, with a double crush zone for a larger contact area). The top part of the rivet needs to be sanded down slightly to fit in the slot in the moulding. These should be the go-to if oversized rivets are needed.
90269-06013 are actually wider than the 05034, at around 5.4mm in width. They are much shorter too, making the final contact area smaller. I’d say avoid these unless absolutely necessary.
The suffix portion of the part number: -05/-06 indicate the nominal diameter in Toyota standard part numbering: Ergo, your measuring results.
Thanks @OGBeno, so it totally makes sense that the diameter moves up when you transition from:
90269-04... 3.2mm diameter
90269-05... 4.9mm diameter
90269-06... 5.4mm diameter (per @tesq above)
Do any of the final 3 numbers in the suffix speak to length or is it not that simple?
