Window replacement, second door, passenger side
KC, MO Area (again)
Yeah. It's like it says. My window on the second door passenger side broke out when the wife (I give credit where credit is due) closed the driver door. I called around local glass shops. They couldn't find one (factory, OME, generic) to replace it. I did source one from a Mud Member (thanks F2 Power). Now how in the world do you install it?
There is a good side to this misfortune. I was able to fix the front power seats so they will move front to back again, replace the head unit with a aftermarket I had on the shelf, and have speakers ready to go in the doors, kneecaps and overhead in the back.
If it's anything like the front windows, it's very easy and self explanatory. Just take off the door panel and carefully pull the moisture guard off. Two screws and you're done.
I have the door panel off, cleaned all the glass out of the door (enlarged the hole for the speaker). Looks like I'm almost there. Thanks AMX390
Dam. I have one of two issues going on. 1. Second door isn't like the fronts and or 2. My eyes deceive me.
I was able to remove the panel and moisture guard but can't find the two screws. Where might they be located? I was able to get the old bracket that held the old window. No screws there. Bracket fell into the bottom of the door. What am I missing here?
I had to go up or down with the regulator to get the screws exposed though one of the openings. The two screws attach the bracket at the bottom of the window to the up and down mechanism (sorry, don't know the term) May need some photos from your end.
Bottom of the bracket that is attached to the window? If so, the old and replacement do not have screws.
When I look in the door I see the motor that moves an arm in an arching movement up/down. at the end of the arm is a wheel/bearing that rolls in the track, bottom of the bracket (picture shown above). In the pictures below, I have found two 10 mm bolts that connect the rear vertical track. First pic is of the bottom bolt. Second pic shows the bottom bolt and the top bolt. the top bolt is behind the connector rods from door handle to door latch on the hinge side of the opening. I would assume that if I remove the two bolts, remove the rear small glass, I could make enough room to the larger glass in. Then I'll have to figure out how to get the smaller glass back in.
Definitely different than the front. Does your new window have the track on it? Looks like it just slides on to the roller bearings. Can't be that hard. You may want to check out the FSM.
It does have the track. I may have a glass replacement company come and install it. I'll be moving in a month or so. Need to figure this out BDQ.
Leave the power connected.
Run window tray up till you see the 10mm bolts in the track that trap the window.
Remove those 2 bolts and you can lift the old window out (yours is obviously gone).
Assembly is the opposite of disassembly.
I would clean/lube your tracks while you have it apart.
I like the dry lube in a aerosol can that doesn't leave a sticky residue to attract dirt.
Give your lock cylinders a quick shot while at it.
Less is Best, in this case.
Did you pull up the FSM? I would say that you are more than half way there
I don't have the FSM handy now, but will refer to it when I get time to work on it again.
Power is still connected.
Currently inside the door I see the motor, arm and wheel/bearing.
I assume the window tray is connected to the bottom of the window as seen in picture of post 6? If so, there were no 10mm bolts in the old window tray. Where are these 10mm bolts? I have a strange feeling that they are in a landfill by now. I cleaned the glass out of the bottom of the door with a shop vac, dumped the vack in the trash and the bolts are more than likely gone.
I have been attempting to fit the replacement window into the door from the top. It seams like the most logical avenue of approach. Is this the correct location to reinstall the window? Do I need to remove anything else like the gasket/seal that encompass the front/rear (vertical) and top (horizontal) edges of the window? The gasket/seal travels down into the door on tracks. Picture 1 on post seven shows the bottom of the track closest the door latch. This track does have two 10mm bolts holding; track in place and small wing window in place.
There are no bolts holding the window glass in the channel. The following is from the 1996 FSM
REPLACEMENT
1. REMOVE GLASS CHANNEL WITH SCREWDRIVER OR LIKE OBJECT
2. APPLY SOAPY WATER TO INSIDE OF WEATHERSTRIP
3. INSTALL CHANNEL BY TAPPING IT WITH PLASTIC HAMMER
There should be 232.4 mm (9.150 in.) from the edge of the channel to the edge of the glass (bottom lower corner of the glass).
Thank you Wayne. I'll see what I can get done and take pictures along the way.
It's easier if you get a glass shop to glue the window into the channel once in place. Getting that thing back on the window, particularly with old channel rubber, is really hard.
Let me see if I can help... The only thing you need to unbolt is the window regulator. the plastic wheel on the regulator slips into the track at the bottom of the glass and you do this with the regulator unbolted and lift the regulator and glass up and bolt the regulator on. That's the easy part..
The problem is getting the glass into the side channels considering you have the fixed 1/4 glass. Hopefully the directions below will help. You don't need to remove the support track between the 1/4 glass and door glass as i did but you need to remove the 3 small bolts that secure the track ....leaving the one on the top edge of the door will allow you to move the track and slip the door glass into the track. Removing the weatherstrip is KEY!
(Weatherstrip goes in last)
Quarter glass goes in first... Bolt the support track on the top edge of the door only... Slip in the door glass and lower it to the bottom of the door. Having just one bolt on the top on the support track allows you to move it just enough to get the door glass into the track and install the regulator
At this point all the was left was to slip the new weatherstrip into the tracks which required a bit of graphite and yes....olive oil... that did the trick and the driver side was done
@Luke111 thanks for the info but I got it figured out before I had a chance to get back here. I agree, getting the glass in the side channels was difficult. I pulled the rubber gasket/weather-strip out, starting at the top corners and worked my way across and down using soapy water. While the gasket/weather-strip was out, I cleaned out any remaining glass, the surface contact areas between the gasket and the door.
It was a tight fit and did take a little wiggling but I was able to slide the replacement into the door frame. I didn't loosen or remove any bolts. Nor did I remove the quarter glass support bracket. I did bend the bottom of the track mounted to the bracket holding the window in order to get the wheel/bearing into the track.
Putting the gasket/weather-strip back in was pretty easy. Hot soapy water did the trick. I started by sliding the weather-strip down the window track on both sides as far as I could. AGAIN Hot Soapy Water works great for this. When the weather-strip would not move down, I rolled the window up enough to get ahold of the bottom so I could push and pull at the same time. I got the top of the weather-strip horizontally lined up and started placing it back into the door track. I started in the center and worked my way to the corners.
The window is now in place, and functions as you would expect. Yes it is still slow and needs help up some times. I'll apply a lube to the contact area between the window and weather-strip.
On to the next project.
