Window issue with power
Arkansas
My passenger front window has an issue I can't figure out. It works one time then stops quarter of the way and works again if unplugged and plugged back in. Attached is a youtube link to a short video I took of the issue. I've replaced the motor, switch and drivers master switch. All other windows work fine and are programmed.
Gx window
Nobody had this issue?
Not sure on my GX because I haven't had that issue, but other window motors detect a spike in electrical draw to signal shut off (up limit, down limit or obstruction) rather than limit switches. I'd bet you have a friction point in its travel that is right on the edge of mimicing an obstruction. Sometimes it triggers, other times not (temp difference, maybe?) But unplugging resets it. That would explain why changing all the components didn't fix it. Just a thought...
