Wind break tarp?
"the whale's vagina", CA
Hey guys, I was looking for something to use as a wind break when my awning is out and I am camping with the family. I am somewhat tired of the cheap home depot tarps that rip. Wondering if anyone has any reccomendations for tarps or companies that sell something specifically made for this use? Would not mind spending a little extra for something that will last and can have multiple uses.
Thanks,
Noah
I've used the Silver coloured tarps from HF for several years of camping in the oz bush. I have a large one (about 30' x 12' roughly) that has been used in hot sun, downpours, strong wind etc and it has survived very well indeed. Easily 10 years worth of trips, 2 weeks in duration and all types of weather. It has not been babied and is still in excellent condition. Highly recommended!
e.g. of use:
cheers,
george
I would use canvas too. Some military supply place would have them. Think they are pretty water proof too, or maybe my buddy treated his.
I like to use nylon tarps for wind breaks. Canvas are great until it rains. Canvas becomes heavy when wet and they generally take longer to dry out. A high quality nylon tarp is light, strong and will last a lifetime.
Just my $0.02
I'd second the harbor freight solid ones.
The Harbor Freight Tarps should work. I have found a set of Tarp Retainers (Tarp Clips, Tarp Grommets, Tie Down Clips) that HF carries. I have looked for them for 20 years and finally found them again at HF, an now cannot find them on their website. See the attached pic. They are yellow, about 1-1/2" in diameter, and you place the "wheel" part on one side of the tarp, and the wrap-over clip on the other side and press them together. This creates a "grommet" without cutting a hole in the tarp. I have used them a LOT for tarps on trailers and such and they do NOT tear the tarps. I wish I could find a picture of them to pass along. I even use one to keep my kids' bed sheets on his bed while he's sleeping so he doesn't end up all wrapped up in the sheets in the middle of the night or having them pulled completely off of him.
My problem with tarps getting torn up is that the grommets rip out and then they shred. This type of grommet doesn't tear them up.
Make sure it is the Silver tarps at HF that you look at. The silver ones are UV resistant and they are also thicker material (versus the blue etc). Where the grommets are installed the material is thicker due to extra layers. For the price they are hard to beat and easy to rinse off if covered in dust/mud from camping. Also great if you need a ground sheet to get under the vehicle for any repairs etc while out bush.
cheers,
george.
It's a pretty sad day when you can't even get a decent TARP from a local store. That used to be one of the easiest purchases to make.
PVC tarps work really well, very hard to tear. The ones you want are a base fabric coated with UV protected PVC. Kind of like the material whitewater rafts are made of. Bunch of places to order online and available in different thicknesses.
Yeah, those Northern Tool ones sound kind of like crap.
I have had a vinyl coated one on my military trailer for a couple years now and it has been super tough, just this spring it has started showing some UV degradation. I THINK it was from mytarp.com http://www.mytarp.com/vinyl-tarps-heavy-duty-18-oz.aspx . I'm probably going to have them build a 5 sided one to fit it better this year.
The other benefit to this type is that the 18oz fabric has some thickness to it, so it doesn't flap in the wind nearly as much.
Thompson's water seal will work on the canvass if you can't find waxed
read some more of the reviews on the pvc ones at northern tool and to me it seems like these are well made? I like the fact they are reinforced all the way around vs. only on the corners like many others.
