Winch cable fused?
St. Louis Area
Greetings:
Gathering information on my upcoming winch install in my Slee bumper. Its an M12000. On my long run between batteries, I am fused at the starting battery. I plan on having the winch power and ground going directly to the aux. battery. Should the positve cable going to the winch be fused at the battery? If so what size fuse.
Thanks,
Steve
94' 185,000
Greetings:
Thanks,
Steve
94' 185,000
that is an interesting question.
I didn't really think about a fuse when I installed mine. Strange.
But considering it draws something like 500A (from memory) that would be less than obvious perhaps. I don't recall seeing anything about fuses in the instructions. I imagine that the relays would go first. Isn't the starter protected by the fusible link? Maybe something like that for the winch then?
None of the many winches I installed for our customers were fused.
:crybaby: Creepy .... if the fuse blow when pulling my cruiser over a water cross.
Anyhow, only when the winch is stalled, it will draw the rated maximum amp.
I'm not sure I see the practical need in "fusing" a cable for the winch.
Long heavy pulls without letting the motor cool down can certainly burn up a winch motor (or severely affect it's performance), but that is easily monitored by the person operating the winch.;)
Perhaps a more useful item would be a disconnect switch in case a solenoid sticks...or to reduce the chance of someone successfully tampering with your winch.
I'm still learning, but as I understand it, there are 2 uses for fuses on a vehicle:
  1. to protect sensitive electronics from power surges; these are installed as closes as possible to the device
  2. to protect the supply cable from causing an electrical fires in a an overload situation; these are installed as close as possible to the power supply (battery or distrubution centre - e.g. fuse block)
A winch isn't very sensitive (compared to a radio) and doesn't need a fuse for power surges.
A properly sized winch cable is not going to overheat enough from a short or overload (there isn't enough power in our batteries) so a fuse isn't required at the battery end.
It's still possible for a short in the cable, solenoids or winch to arc and cause a fire, but a fuse wouldn't prevent it because the fuse has to be rated high enough for the full load of the winch.
Winches and other high current loads usually aren't fused on a vehicle.
-Steve
x2 on the disconnect switch - IMO that would be MUCH more valuable/useful/helpful. FWIW there is NO mention in any of the Warn user manuals I've looked at that state you should add a fuse. Of course they don't mention using a disconnect switch either :hillbilly:
Case in point about the possible usefulness of a disconnect switch...On my club's annual snow run I got stuck bad (why my LX's nickname is now "The Whale" :D)
No problem, pull the winch line out, strap to a tree, and reel myself out, right? Well, when I hit the remote button to spool in the slack winch line the winch wouldn't turn off (which is why I now call my winch "Damien"). No problem, hit the remote button the other way. Nothing. Ok, disconnect the remote control. Crap, that didn't do anything either. Panic sets in as my line is now being pulled in uncontrolably :eek: - luckily my buddy ran out a LOT of extra line. As one person runs toward the tree saver connection point to disconnect the line, I run to pop the hood. A faster thinking club member (wisely) rotates the clutch knob to free spool position :clap:
With Damien in free spool "mode", it was much less of a panic to remove power to the winch.
Now, after all is said and done if I had a disconnect switch I could have just used that to remove power to the winch at the first sign of trouble (assuming it is accessible from outside of the engine compartment.
Another point to consider is that it is possible to damage the power cable from the battery to the winch in an accident. This has happened (not to me luckily) in the past causing where the power cable got pinced and this led to undesireable results. If you had a disconnect switch then you can leave power to the winch OFF until it is needed and avoid this possibility alltogether.
After my experience on the snow run my plan is to install a disconnect switch for my winch. I may never have another problem with my winch but the peace of mind will be worth the cost :steer:
and as has been discussed here before, a disconnect will prevent the dreaded roof taco issue, of course. :)
Great information! Thanks.
A disconnect switch close to the Battery to prevent a short circuit due to a "pinched" cable, unauthorized usage, and to cut power in a hurry seems to be the answer.
Steve
94'
185,000
Switched & Fused winch connection
Let me preface by saying I have a weird setup.
I have two factory matched D31A Optima Yellow tops running in parallel. Each has a 300amp marine fuse at the battery. The batteries run to two switches. One switch handles the 'house' load (everything else). The other switch handles the winch.
With the parallel system pulling from two batteries it can provide a 600amp circuit to the winch, the house or both.
There are disadvantages to this setup. It is not 'automatic' on the dual battery side and needs to be run in parallel to keep the system charged.
However, it is fused and switched and the winch or house can be disabled by turning a dial. The details on it can be found in the dual battery FAQ.
YMMV
Rather than a fuse.
Example of a battery disconnect.
This is how I did it on my Bronco (yeah...I know, not Toyota).
Rather than a fuse.
very clean, but wouldn't you rather keep the key in the cab for safety?
The photo shows the key in place and the contacts in the closed position.
When not in use, I drop it behind the grill. It is tethered to a piece of cable.
You can't see it at all unless you are really looking for it. I have a spare on a key chain as well.
I wouldn't recommend leaving it in place on a DD of course.
This is on a ranch/hunting vehicle and only myself or other trusted persons are ever around it.
Your point is a good one though.;)
Rather than a fuse.
VERY nice :cool:
I think I'll flatter you and copy that :D
Rather than a fuse.
This setup is waaaaay better than a marine battery switch.
This type of switch can handle a lot more current; my winch is hooked directly to my second battery and I use a switch like this to hook my third battery in parallel to my second battery to provide enough ooomp to the winch:grinpimp:
Heavy diesel trucks use this switch to disconnect the ground from the battery and is from were I source them.
That is how I did this one as well.
Very easy and inexpensive.
For my purposes, it is not to discourage vandals (taco my bronco) but is there as a means to stop the winch (as quickly as possible) if something should go wrong.
When you are working with something as powerful as a winch, you need to be extra careful. I can imagine all kinds of really bad scenarios involving a "run away" winch.
In some instances...you might be able to disengage the clutch. But on an 8274...this would require a herculean effort if there was much pressure on the winch line.
I prefer to be prepared.
Very good advice. I'm not sure if we would have been able to disengage the clutch on my XD had it actually been under load at the time.
Question for you...Are you concerned about the amp rating of the disconnect switch? Quick search netted ones that will handle 450amp continuous for ~$100 bones.
My XD9000 (per Warn) can get up to 460 amps max so obviously I want to find a switch that will support that rating, or as close to it as I can get correct?
This is exactly why I added it as well :)
That little winch came with a wireless remote, but the receiver had a timed delay, so it would actually take a couple of seconds to stop after you let go of the button :o (not good when you need to be in total control)
I hard wired it to a toggle switch on the dash and use the main switch to stop it when working on the winch end for safety :cool:
Also, even with my dinky winch, I can't disengage the clutch if the rope has any kind of tension on it, so that wouldn't help at all :doh:
My FJ-40 has a 20 years old 8274 and as you noted , disengaging the clutch is not a easy task. This older version draws a lot of amps.
Regarding the vandals, 3 years ago somebody did a ugly vengeance against a student in his college parking lot: they loose the clutch of the M10000 on his nearly new FJ-70, released the wire over the hood, the roof, rear and then under the Land Cruiser till the front, and engaged again the clutch, then they short two pins of the remote female socket with a wire !!!!!!!
The winch wire crushed the roof, the hood and both rear and front windows, until stalled and discharged the battery, which for the owner of course was the least of the problems.
Fortunately there were no fire but damages were severe. Since then all the students from his college who had winches disconnected the positive winch wire from the battery and protected the hood with a lock.
My brother in law in his FJ-60 has a marine battery and hook and unhook the winch positive wire releasing the butterfly nut that came with the posts of this battery, cheap solution but works fine.
The one I have has a 1000 amp. "surge" rating. I have run it many times for over 60 seconds with no problem (on ground side).
I don't like to run my winch motor much more than 1 minute at a time (on heavy pulls) without letting it cool some. With the 8274 you'd have a pretty long pull to not be unstuck after a minute of winching.
It has worked well for me, but I am sure someone could push it to the failure point.
With that in mind (always thinking), I left enough length in my cable to be able to put both eyelets on the same post (toward winch) just in case the contacts failed during use. Basically, putting it back to a solid connection.
But....I've never had any problem with it.
