Wild wobble...
DEN
About a week ago I had very shaky incident in my FJ. I was driving straight on a paved road and hit a small water runoff that is purposely made in the road. Normally it would be a bump and no problem. But this time the bump was followed by the steering wheel shaking violently it seemed back and forth. It felt like the drivers side front wheel was about to fall off or I had a blow out. I slowed and within 15 feet the shaking stopped and all was okay. I since have driven around my neighborhood side streets at up to 50 mph with no wobble. Seems fine.
I have hit bumps since then and nothing but Today, it happened again. Same feeling. I noticed my leaf springs are slightly misaligned from one another..Possible loose u bolts...Also I had the truck aligned and checked knuckle stud bolts. Am I correct to suspect bad steering bearings..
Please help I'd like to fix quickly... Thanks
I occasionally get a bit of death wobble on flat ground. I can't find anything loose, i've had the tires rebalanced, and it happens at no particular speed, but always over 40. I have no idea when the knuckles were serviced last, so i'm hoping that is it. It's on my list for this winter.
I definitely think the very violent shaking I experienced is not normal for any vehicle. It seriously feels like it could shake you out of the truck. I searched death wobble but did not know if it is the same because I have no wobble at any speed, that is until I hit that certain size bump and then its on.
I read that possibly the steering bearings could be the problem...I really don't want to drive anywhere around other vehicles with this problem. Also it wasn't happening the 1st 5 months I owned the vehicle..... Thanks
Are you running a steering stabilizer? Could it be junk? Is your steering in good shape? Rod ends, center arm, wheel bearings tight, knuckle bearings?
Is it sprung over? Under?
more info.
I've never had death wobble except once on a motorcycle. But I have read volumes, here and elsewhere, on the topic. Here is what I have found;
1 - It's not a Cruiser thing, any vehicle can suffer from death wobble. It is far more common in vehicles with larger tires.
2 - Stabilizers usually just mask the condition.
3 - Out of balance tires are the most frequent cause.
4 - Worn ball joints run a close second, does not apply to FJ40.
5 - Bad castor/toe angle as the result of a lift is in the top five.
6 - Worn/lose Tie rod ends.
Hey bluecruiser, there are a ton of older cruisers out there that have been modified, tinkered with, rigged, neglected and otherwise abused beyond anything that Toyota envisioned when it shipped the unit. Unfortunately, we're lucky if we even know what the most recent PO did to the truck.
Steering problems can be caused by anything from failed tie rod ends to mis-adjusted or ruined trunion bearings to ill-fitting or worn leaf-spring bushings to steering gear maladjustment to failed steering dampers (although these tend to mask other problems) to extreme wheel bearing failure to severely worn tires to . . . well, you get the idea. And these are only examples of the final, diagnosable and repairable problems--there are an exponentially larger number of issues that result in these repairable problems.
I apologize for not being able to recognize or diagnose your specific problem. That said, there's something wrong with your steering, and you should fix it before you endanger someone else on the road. Driving this rig knowing that it's got a problem may set you up for punitive damages in court. This goes for anyone else who drives his or her cruiser on the road knowing it has death wobble, steering issues, braking issues, or other safety problems.
Nick the Carpenter said:
cruiser do this all the time, worse with wide wheels.It is a cruiser thing
i disagree, mine has never done this, i do have power steering as of a month ago. before i never had the death wobble either.
reuild knuckles and replace worn out parts, porbaly half the old cars out there have never had there steering parts changed or maintained
:cheers:
Any ubolts not tight would cause this, so would loose knuckle bolts. Hit those first. The more violent and uncontrollable the wobble, the more likely one of these is the cause.
Worn tie rod ends, steering link ends, center arm (if using stock FJ40 steering systems), suspension bushings, and knuckle bearings are next most likely. This would result in an unpleasant but still controllable wobble. Very large, unbalanced tires or bent wheels would fall in this category as well.
Also, look for general damage like broken or cracked frame (if you have added power steering, check aroung the mounting bracket welds/holes and weak spots on the outside of the front frame horns), broken leaf springs, etc.
One useful debugging step is to have someone sit in the vehicle and turn the wheel side to side while sitting still (the vehicle, not necessarily the person). While that is happening, crawl around and look for things flexing or moving that should not be doing either.
-Rick
Thanks for all the response. I want to replace the front u bolts right away. The PO bent them so I will need to cut them off. Can I use any u-bolts or are there FJ40 specific ones?
I have Power steering, I have jacked up the front and turned the wheel and checked everything.. All is tight and the steering stabilizer is pretty new (about a year old) The tie rod functions and pivots well. This is so strange how it drives fine then all hell breaks loose.
I will have my tires balanced too. Thanks again to all
Also how does a knuckle bearing effect this problem? Does it get loose or develop a "bad spot" works fine until you hit the right bump at the right speed?
I don't know when the bearings were last inspected/replaced? I definitely have a checklist of things to inspect. I am suspecting bearings also. Any other tips are definitely welcome
Thanks
Bluecruiser-
I just went through this last spring. I would do the easiest stuff first, only because I replaced the TRE, stabilizer, center arm, and rebuilt the knuckles... the issue was out of round tires.
I would try to find another cruiser around your area and see if you can swap tires for a day or so and see if it clears it up.
Any of the above reasons could affect the steering wobble, but I would start easy and work your way up.
Also, check for steering play with the tires on the ground, not up in the air.
Best of luck, this is a frustrating situation for sure!
Rezarf <><
bluecruiser: Also how does a knuckle bearing effect this problem? Does it get loose or develop a "bad spot" works fine until you hit the right bump at the right speed?
These are the bearings that allow the knuckle to pivot left and right on the fixed axle housing. There are two per side, one at the top of the knuckle and one at the bottom. The top one is under the steering arm and the bottom one is held in by the 4-studded cap at the bottom of the knuckle.
Like any other steering component, if they are worn (bad spots in your question, or worse) or even if the bearing pre-load is no longer correct for your front-end set-up, they will allow movement. The curious thing is that your problem doesn't show until you hit the bump--that's odd for a knuckle bearing. Others may have better ideas, but I suspect that you could detect a major knuckle bearing problem by lifting the front tires off the ground, grabbing the top and bottom of the tire and trying to rock it in and out at the top and bottom. If you feel play, there's a problem.
Checking the pre-load requires actually tearing apart the knuckle. Since there are some very good suggestions in this thread that are not as time-consuming or expensive as a knuckle rebuild--and may detect some other, easier to cure problem--I wouldn't tear into the knuckle until you've ruled-out the other potential problems. 'Course, you'll do it eventually anyway . . .
I lifted the front and grabbed and shaken the tires no wobble, shake, give at all. I am have tires spun and balanced this week then new ubolts .
Thanks for all the help for my very frustrating problem.
