Hey ggmanning, any other parts you're giving away? LOL.I have one I'd give to you but you are too far away to pick it up. Anybody near NC need one give me a shout.
I had one like this on my previous 60, 4 bolts to the side channels, two into the bottom of the crossmember.
Would the class rating be based on the engine's power or the strength of the frame?
Ive seen 2" receivers on Subaru Foresters.
...and the suspension, brakes wheelbase etc. The ratings are for manufacturer liability and are usually quite conservative. I've seen VW Bugs pulling trailers. I'm sure that's not what Hitler had in mind
Good find! Thanks for posting.OK, I got extremely lucky tonight at the local U-Haul store. I measured my frame rails inside and out, roughly 38"/42" inside/outside measurements. Then I went to the rack where they keep all the receiver hitches IN STOCK! and checked for ones that might fit. The second one I tried fit amazing. It lands on the rails perfectly and the unbelievable part is that there are two holes near the receiver tube that also line up perfectly with the bumper bolts. I got it home, bolted up the two bolts on the underside of the stock bumper, that held it in place so I could drill the holes in the frame rails. As it turns out there was a hole on each side that lined up there too. This made me smile so I only needed to drill two holes for 6 bolts, not too shabby. FYI the picture of this hitch is not accurate on the U-Haul website
The U-Haul part # is 78300.
Paid $190 for the convenience
I've seen a light 2 inch receiver hitch on the Man-A-Fre website- seems to bolt into the cross member behind the bumper!
I have a feeling you know someone who makes really nice ones!The factory bumper wasn't rated by Toyota for towing. I don't think it would fare well to towing. There are some aftermarket bumpers that
are built for towing that will do fine
That means I could either go to wrecker and seek Thaoes, Yukons out other chevys, as they probably have something similar.
Shipping to Norway would be killing the deal.
Can you post up some pictures of it mounted?
Done!
