Who still makes a 2" receiver hitch?
@bluefish its always something isn't it! It looks like per post# 58, you solved your issue. When you get a chance post some pics. For what its worth here is my setup. I can't remember exactly what holes I used, as the PO already had a makeshift ball hitch mounted on my frame. I reused two holes, and had to drill two additional holes.
I do have a gap between the bumper and the hitch plate where the two holes mount into the frame. At some point I should put a metal plate in there.
I just bought the 75725 for my ‘88 62.
it comes with only 4 frame bolts Two for each side, but there is three holes for each angle to the frame. Comes with two bumper bolts. Going to go buy new hardware for frame so I don’t have to tap the frame as the bolts don’t have nuts and lock washers look like they are supposed to thread into frame.
And like everyone Says only one set of holes lined up. But my bumper holes did line up well.
Drilled two in frame one on either side at the front hole in the hitch angle.
I am trying to avoid drilling the third holes on each side due to they are right where there are rivet heads on my frame.
Did anyone only put two frame bolts in? 4 total, 2 each side, instead of using all holes?
I’m just using it for a bike rack and utility trailer... no boats or campers.
instead of washers wonder of short sections of thick walled steel pipe would work at the bumper as a spacer?
