Hi guys,
I'm struggling with a decision.
I have a spectacular condition 1995 K1500 (i.e. 4x4 with part-time 4x4 and open diffs) Chevy Tahoe with the 6.5 Turbo Diesel. I've owned it for 10 years, and I've built it up to a high level of performance and reliability. Specifically:
* 3" body lift
* 15" Centerline wheels with 33" Firestone Destination ATs (Super smooth on the freeway!) with full-sized spare externally mounted on custom swing-away mount.
* HyperTech chip = more fuel, more turbo pressure, firmer shift points from the transmission.
* Flowmaster crossover/downpipe, hogged out intake, '97 air cleaner assembly with factory filter
* #280 flex-a-lite electric fans
* PowerSlot brake rotors
* Hellwig sway bars front and rear, with urethane bushings.
* Rancho adjustable shocks
* Cab lights, nerf step bars, husky liners
* Heath FSD (Fuel Solenoid Driver) Isolator, Health HD Lift Pump
* OPS (Oil Pressure Switch) Relay Mod
* 170 Amp Alternator (sure helps with the electric fans).
* 0-60 in 9.5 seconds!!! and an average of 13-16MPG on #2 diesel.
* I haven't dynoed it, but I'd estimate it to be around 200++HP and 400++ lb-ft of torque!
In summary, I've turned it into a bit of a SUV hot-rod.
I recently picked up a white 3x locked 1997 FZJ80 from it's first owner with 200K miles. Now that I've had it for a couple of months, I realize that it hasn't received as much care as my Tahoe. Example: It appears that someone bypassed the A/C wiring and put in a manual switch that controls the A/C clutch... and they just twisted the wires together at the ends and applied electrical tape(!!!). Lots of other signs of lackluster maintenance and care... broken power seats, fading plastics and rubber, split leather, smelly interior with stains and rubbish, and broken rear-wiper. Other than that, it does smoke a bit at startup, and the front end feels a bit loose. Other than that, it runs fine. I ran a compression test on it, and it's basically 180 straight across all 6 cylinders. Shifts are firm and solid, and it doesn't appear to have any body damage or other issues. No rust.
I've actually had a lot of fun fixing the various bits on it... and everything actually works now (although it still smokes and I haven't finished baselining it... e.g. axle rebuild, etc.).
So... thanks for reading this far. Here's the question.
I've agreed to sell ONE of the vehicles as we now officially have too many to fit in the garage. I'm torn between the two vehicles. My thumbnail comparison:
Fun and power factor= Tahoe
Reliability factor = 80
Parts availability = tie
Convenience and Utility = 80 (2 more doors, greater cargo area, lots easier for family to get in and out, etc.)
Looks = Tahoe (this is subjective I know)
Upgradeability = 80
Support network = 80 (iH8MUD is king!)
Underlying capability = 80 (Full-time 4WD plus lockers beats RWD and open diffs)
Quality of build and design = 80
Safety = 80 (although neither have safety test results, the 80 has a high build quality and dual air bags)
Electronics = 80 (80 has OBD2 and better design to boot)
What is your opinion... which should go and which should stay and why? BTW, I have eliminated the "Bling wheels" and the 80 is back to stock wheels and tires (Michelins).
* 3" body lift
Upgradeability = 80
