I've had my burgundy 80 (1996) for about a year, and done some light wheeling so far. As much as I like the rig, I always wanted one with lockers (ARB or factory). Recently I came across a white 80 (also a 1996) with factory lockers and decided to buy it. Here's a few details on each:
Burgundy 80:
- 195k miles.
- Interior is in better condition (head liner, rear & third row seats (front seats have been re-upholstered), dashboard, door seals, seatbelts, etc)).
- Body is in better condition, no dents... even though I may get some in the future
- Need to add a quart of oil @every 800 miles. The oil pump cover is leaking a bit, bit I think majority of the loss is being burned through bad valve stem seals.
- Previous owner had recently replaced the radiator and starter.
White 80:
- 189k miles. The trip mileage counter isn't working... how hard is it to get this fixed?
- Factory lockers
- Seems to have been a bit neglected and not looked after very well over the years.
- Previous owner said that it had a head gasket leak about a year ago. That was repaired along with a valve job... so it feels a bit smoother and a bit more responsive when driving it.
- The head liner is stained quite a bit, the dashboard has one crack (above the center of the gauge cluster up to the windshield), the steering wheel and the gear selection knob are worn badly.
- Got a couple of small dents on the body
Which one should I keep? Both need the oil pump cover seal replaced. The burgundy 80 has larger tires (285x75x16), so it looks a bit better in the picture. If I keep the burgundy one, I will have to swap the axles into it. How tough of a job is this? Am I better off keeping the white one (as the head was recently redone, or should I be worried, as this isn't usually necessary at this mileage?), and swapping everything I like from the red one into it such as the headliner (is this even possible), seats, dashboard, etc.?
I've thought about this quite a bit, and currently leaning towards keeping the burgundy 80. Reasons include me having driven it @7k miles with no issues, and the color is a bit more unique. I gotta admit though, even the white one is a beauty and is kind of growing on me!!
Burgundy 80:
- 195k miles.
White 80:
- Factory lockers
