Where to find - Seal, center arm dust, lower
David*BJ70
Looking forward to reach the end of the world
Montréal, Canada
Where can I find the SEAL, CENTER ARM DUST, LOWER.
I call my Toyota dealer and the part is not available anywhere in north america.
Can you give me a nice Cruiser parts supplier that sell a good quality remplacement part ?
Any other cross reference can help.
Merci.
David i think i have one....let me go check
but i beleive i bought mine at the dealer.
EDIT: couldn't find it in the garage, so it must be in the "cabanon......" and no way to enter there with the snow...
Bring the seal to General's Bearings service. The will find something good for you. Ask for metal one or double lips if they have it. This seal doesn't need to be bullet proof, it's keep some grease inside and do zero effort or have zero stress on it.
I need to ask, what make you beleive it need replacement?. (pas que je veux douter de tes compétance mécanique mais je suis curieux)
Je suis dans ma semaine de vacance... je devais trouver quelque chose à faire ;)
Le nipple de graissage était brisé le filet dans le housing. Je démonte pour le rempacer + faire un peu d'entretient et j'ai abîmé le seal au passage en voulant retirer le bras du pivot avec une fourche. :(
Bummer. (Le bummer.) Hope you can find one.
seal
Bearing supply house
25x38x7
Pretty standard seal
You could install it upside down from the normal way so the grease can get out( when you grease it) and the water can't get in.
Thanks jb
cruiseroutfitters.com
For those working on a similar project, the OEM seal on a late model (1982 FJ40) is Koyo CR MH (OD wall is rubber material, no internal spring, without minor lip) 25x38xJ6 installed backward to so grease can be pushed out.
