Wheels question...again
Plant City, Florida
When i got this 1976 FJ40 it had 33x12.5x15 on it that were too big and rubbing. I wanted to go 16”. So after a bunch of research I bought some 16” trailer wheels (only way to get the 3.5” backing without pay big bucks for custom wheels). When I went to put them on just now I found the hit the caliper, but I have another trailer wheel that fits. The shop that mounted them did not notice that they were hitting the caliper I guess and so they we not fitted right. I didn’t notice a the time and have since put new calipers and rebuilt the hubs. I drove to my garage about 2 miles and its been up on stands since. I checked the wheels and you can see where the old calipers were rubbing the wheel. See pics. So the wheels I need have to angle out quickly after they leave the hub/flange. I need another 1/4-1/2” to miss the caliper. Either I need spacers or different wheels. The black wheel pics are my new wheels. Also a pic of the caliper sticking out past the rotor. Any ideas?
What size tire are you looking for?
OEM wheels are the obvious answer.
I had hoped to go with16” rims and a tall/skinny look, but may have to go back to 15”. I’d like to stay at tires that are 10.5-11.5 wide. 12.5 wasn’t working. Something like a 33x11x15 or 16”. Just have to find wheels with the right backspacing. Rather not do spacers. I’d be OK with OEM wheels I guess.
oems are still available new from the dealer in 15s.
and some vendors here in 16.
the clear choice of tire is a bgf in 33X10.5.
I assume those will fit on stock 15” rims? I haven’t found a vendor offering a 16” with the right spacing (except custom). Do you know of one?
I bought Kenda Klever MT 235/85x16 which I like and have on my Landrover. So another new 16” rim would be nice but....
If the caliper is just barely scraping the rim, you can grind it away. If you can find old 16” chevy steelies, they can be made to work. Just need to bore the centers out.
You might also look into FJ cruiser steel rims. I think they fit, but haven’t researched it.
Yep tires fit just fine
City racer LLC for 16 OEM steelies.
A 1/4 inch spacer would probably fix that I know you said you’d rather not but 1/4 inch is not a big deal.
One possible problem with spacers is if the studs are too short then the lug nuts don't have enough threads. The right rims are a better answer.
