Hi All,
9/75 FJ40. I have the harness laid out to clean it up. My rig has a small block chevy conversion from a PO, so I had a lot of unneeded wiring in place (i.e., emissions systems wiring, etc).
One wire has me confused. I have the 1975 Chassis and Body repair manual, but I can't figure this one out.
There's a solid red wire on the rear harness that branches off right next to transmission sender/sensor (aka "backup light switch" on the diagram). I'm pointing to it in this pic. The other two wires go to the backup light switch. I did a good job labeling wires in general, but I didn't label this one. The plug was caked full of grease and mud (cleaned before this pic), so I suspect it was not plugged in to anything. But I don't want to remove it if I'm simply forgetting what it was for.
Further upstream, it joins in to a blue/red wire, which my understanding are all connected to the ACC circuit. Pic here:
It's definitely factory original.
Does anybody know what this is? The wiring diagram only shows two solid red wires that I can find: one that goes between the ignitor and the distributor (n/a for my SBC conversion), and one that goes from the headlight switch to the fuse block. I see no other solid red wires.
Thanks in advance!!
Peter
Thanks in advance!!
Peter
