I had the 5.29 R&P installed yesterday turning my 35" trxus. Oh, what a difference at my elevation, which is 7K ft. I have the speedo gear for 285's on stock gears, and the 5.29's are turning more than the increase in tire size, so the speedo is reading about 10 mph over actual speed - I'll be going back to a stock speedo gear.
The 5.29's are nowhere near as high in RPM in OD as running OD off with stock gears. I am in the break-in period, so I won't be testing high RPM or speeds, but they feel like an excellent ratio so far, and I am very glad that I went 5.29 over 4.88. I don't drive over 70 mph, so I have lost nothing in top speed.
As for pinion strength, I am on 35's and will be staying on 35's, and my install guy (LEXUSBEN) said the trick for the front install is to add preload to the bearings, which are large enough to handle it, so the carrier can't move even in the typical breakage scenario of pulling load in reverse. R&P breakage is usually due to something moving (housing flex, carrier movement) even in very weak axles. So time will tell, of course, but going low has completely changed the feel of my 80, and my wheeling style shouldn't be threatening the R&P.
I'll post up again as I get the speedo corrected and gears broken in on RPM's at different speeds as well as offroad gains. The stock gears were eating me alive at high elevation rock crawling, can't wait to get out again.
