Is this on both the 60 and 62? And if Mine (60) is desmoged, then I probably don't have it any more, iwould this also be correct?
Thanks for the pics.
Is there a good reason not to put loc-tite on the bolt?
Just snug it down (don't overtighten it, just snug)
Come on guys, I can't believe this nonsense is still continuing. RTFM! - the screw is NON-ADJUSTABLE and for calibrating the action of the damper, NOT for snugging things down. If you snug it down you've defeated the purpose of the damper by fixing the volume of the fuel rail. If the damper is defective and leaking, replace it, otherwise leave it alone.
Bill
If the screw has worked its way out, what do you suggest I do?
Bill
Follow up.....found screw and o ring...It does make a difference!!! I'm going to order the part from Toyota and replace it with a new one. The guy at the toyota bone yard said that once the screw is out your damper is shot. I'll keep you guys posted with a mileage report.
Alright. The screw was all the way out on mine. Let's see if I can go from 10mpg back to the respectable 15-17mpg I got when the 62 was brand new.
i want a magic screw for my 60![]()
