I just pulled my 1HD-T out of my HDJ81 and I will be putting it into a FZJ80 in about a month. (Waiting on transmission from Oz.)
It was running fine with 283,000 kms on the clock. BEBs are 70,000 kms old and timing belt is 90,000 kms old. I will do both of those while the engine is out. Also rear main seal since it has been leaking a bit.
So for all you 1HD-T gurus out there, if you had your engine on a stand for a month, what else would you check/replace? Is it worth pulling the head to do valve stem seals? Should I check crank bearings? New rings to see if they help reduce smoke?
I don't want to waste my time, but I want to take advantage of having it out!
