what rear speakers are you guys using (FJ62)?
los angeles,ca
Hi guys, I'm slowly getting around to fixing everything and doing a mild restoration on my FJ62. Im going for a stock looking truck. I replaced the rear speakers with pioneers awhile ago, neither the pioneer grills or the oem grills would fit under the oem metal outer grill. I have since lost the grills that came with the pioneers as well at the stock ones. I was wondering if anyone has found some decent 6 1/2 speakers that look good under the oem metal outer grill. Ideally a set that comes with a grill that fits under the oem outer one.
Thanks in advance
I used some MB Quart DK1-113 speakers, easy install and sound good.
Are those stock mounts? If so they are long gone from my 62! Would be interested in any how-tos on that setup. Clean.
Part #86209-90A00, same for both sides. The speaker box is 86151-90K01 and the outer grille is 86269-90K01. Brackets are NLA, boxes are pricey at $110.48 each, same with the outer grilles at $129.70 each. You should easily find these used here one MUD - check the Parting Out forum. I think cruiserjunktion may have some also.
From Megazip:
86161D
86161-90A01
Bracket, Speaker, Rear
[08.1987 - 01.1990] FJ62,HJ61..VX
Japanese Warehouse
3...5 business days
US $40.53
Average handling time
1 pc of this part is used in this component. Price is shown for 1 pc.
6x9 Rockford Fosgates
this is what it looks like currently, anyone find a speaker and grill that combo that looks good under the oem outer grills?View attachment 1869678
I have the Polk audio db652 and use the stock grills. At first I thought I couldn’t use the grills but realized I just had to grind down the 4 tabs on the edge of the speaker frame and they fit perfectly:
with tabs ground off
Installed behind the stock grill. The speakers are pretty cheap, sound good and are marine rated which is good because my dog likes to swim and shake off on the ride home!
I just installed some Retrosound S-62’s this weekend. I didn’t have the stock grills but I think these look pretty good and unobtrusive. I had to drill some holes in the speaker frames to get them to mount up to the factory holes but it turned out good.
