What is this? Dimond in the very ruff?
Pangia, southern highlands, P.N.G.
Hi guys I'm usually over in the 70 forum as I have a LJ78. I saw this cruiser back in the bush a few weeks ago and I'm wondering what it is. And if I could put it on a 75 chassis or a troupe chassis. I love the look of it and I'm sure the village would give it to me if I wanted it
[/IMG]
Sent from my iPhone using IH8MUDp
Appears to be a 4X series troopy of some kind with a pickup cap added. There was a thread a few years back in the 45 section about if this were made at the factory by Toyota or make up later by someone else.
This cruiser is way back in the bush and has been there for a long time. Where can I look for some id #s? I'm sure that the engine, trans, transfer case, are all trashed. So what engine trans would "bolt" in?
I agree with livinginthepast.
Not a 45 swb as there is no division between the cab and box. Maybe a MWB.
The vin would tell us the story.
Give a gift to the village and rid them of that eye sore.
You won't regret it.
It has a tub not a box I would say it is a modified cab on it , troopy by the looks of the distance between the door and the front wheel well.
Chances are a 2F engine, H41 4speed transmission and the 4speed transfer case would bolt right in....assuming the stock driveshafts are still hanging underneath. Too hard to see if the axles, etc. are still there.
That wheelbase gives you some driveline options, but if you are looking to bolt up to existing motor mounts, the above is a good starting point....assuming the motor mounts are still there, and the frame isn't toast, and........
What engines were available for your market? Gas or diesel? You have an LJ78 so I'm going to guess diesel. So in that case that could have originated as an HJ45/47 troopy, so an H/2H/1HZ should fit up ok.
Hi Matt, here in P.N.G. It's Toyota land 9 out of 10 vehicles are toyotas. 77,78,75, hiaces, coasters, hiluxs, 80, the odd 60 and the new 76. This is yota land.
O, and 99% diesel!!
Me and my boys went to go investigate a little more here is the ID tag
[/IMG]
The motor is there and trans/tc as well. The front axle housing and diff are present but no knuckles or steering linkage.
[/IMG]
[/IMG]
Chad Wells
Here is a few more pictures.
[/IMG]
[/IMG]
[/IMG]
It definitely has some rusted out spots but not as bad as I thought.
Chad
Chad Wells
looks great. how are you gonna get it home?:popcorn:
That's a good question. I think we will take it all apart, the guys will carry it down to the river, where I can pick it up with the big truck!
Chad Wells
