What have you done to your Land Cruiser this week?
I believe 8.5 qts with filter, not many engines have this capacity
Prepping for an old air hurricane ac system. Made some brackets with torque nuts and welded it to the radiator housing for the condenser. Also verified the fit of the compressor bracket/ belt and took it apart for paint. Next is to continue the fitment of the unit in the cabin/firewall. More good news - the drier fits great under the radiator overflow (lower pic) I installed a bit ago..getting all my cooling goodies packed in nicely👍
What did you do to eliminate the backing plates?
@orangefj45 sells a plate that takes up that space and then you use one of his braided brake lines to go directly to the caliper
Completed the Sniper install. The ol beast fired right up (once Ifigured out that I hadn’t reconnected the battery ground strap 🤓). She ran a little rough until the engine warmed up and the Sniper went into learn mode, but then quickly settled down. Idle and acceleration are much better than with the carb, but don’t notice much difference at cruising speed. I went with the external Walbro frame rail fuel pump. I can hear it cycle when I turn the ignition on, but don’t hear it at all once the engine is running unless I get close underneath the frame.
Thanks again to Mr Mosley and others on this forum for the installation tips!I
(Note : The hard fuel line and air cleaner adapter both came from Mr Mosley and worked well.)
Who is Montana Jack? Is there a website? Your link is to the Warn 98381 that Amazon sells.
What I can't tell is how the Warn 98381 unit compares to the Gigglepin mega unit.
They sell a lot of parts for 8274s. I called asking about an alrbight contactor because I didn't want to buy one from overseas and they gave me that warn part number.
