The sliders are in two pieces essentially, the brackets that bolt onto frame then the sliders itself bolt on to the brackets. So you will need to take the sliders off the brackets to access the bleeders. If you look at the picture, you will see the 8 bolts on the sliders which will be connected to the brackets.Sorry to bug you, but how are the bleeders accessible here?
Totally a go!I visited @MTKID again in my way back though Montana.
View attachment 3299432View attachment 3299433View attachment 3299434View attachment 3299431
I definitely see a path to 37s up front. Pinch weld and BMC and bump stops. Rear is a little more complicated with the Dissent. I’d need to slide it back or more likely section it.
But 4.88s first. Must stay focused
I don’t but I doubt they are heavier than my tire + hi-lift Jack. The swing out never complains lol.Added Gamiviti spare tire receiver and multi plate for my maxxtraxx and also added a trasheroo.
View attachment 3299593View attachment 3299594
I may raise the plate a bit. I just wanted to get stuff off the roof and think will be more convenient to get the boards out (except I added the trasheroo, so we’ll see).
Anyone know the max weight you can have in the Dissent tire swingout? 4 Extreme boards are heavy.
Thanks for the posting. Six hours after you posted, I was going online to ask the very question for which you posted the solution. I had to cut somewhat more than you did so the shackle fits.Added ARB recovery points. I have the ironman front bumper which blocks the recovery points. I ended up just cutting and grinding back a little corner of the bumper so the recovery points were accessable. I think I saw someone else on here do the same. Not ideal but we'll see how it goes.
View attachment 3299559View attachment 3299560
or Victory 4x4 covers2nd Row A/V Delete
I removed the A/V screens a long time ago and forgot about the holes because I never sit back there. We had some guests back there when we were in Zion last month and I felt bad. It was about the limits of my 3D design skills and my printers capabilities, but I got them covered up.
Did you run power up to the Gamiviti plate?Set up my cockpit for upcoming adventure. Still working on optimizing the layout. I am sure I will learn my favorite set up after some good long term use. View attachment 3300359View attachment 3300360
