Ok, how did you install the ram mount bracket. Is that home fab, or a bracket I can buy? Thanks
@SierraWheeler, nice switching panel for the lights. Do you have a link for it, or at least who's producing it?
store.switchpros.com
Reinforced my ipad. It used to have just 1 ram arm and wobbled quite a bit so now it has 2. It's rock solid.
Also finished routing wires for my budget ham radio install. Really liking how the remote speaker mic turned out.
Also started to install this fun little guy.
What breather kit is that?
You got it right! I didn’t like how all of the other kits used that plastic tubing with push-in connectors. So I actually decided to make my own kit that uses 1/4” ID fuel line similar what we have with the stock breathers.
Started with a viair 6-port manifold and a 1/4 NPT brass sintered filter off of Amazon, then picked up the brass connectors at the local hardware store. Will run 1/4” ID fuel lines to connect everything up. I’m expecting the whole thing to cost me around $75. Not the cheapest or easiest solution, but it was a small price to get exactly what it is that I wanted.
Wow you did an amazing job on these and I love the adjustability!!! Got any other products on your mind or in the works?? Unless that info is classified
Thanks, just ordered one!Switches courtesy of Switch-Pros. It’s a really slick unit. Expensive but very well designed. I can program the unit and control all of the lights wirelessly with my iPad.
SP9100 Switch Panel Power System
Bracket courtesy of pro-fit. The bracket does flex left to right quite a bit so if you mount something heavy on there it will need another anchor point to make it stable.
Wow you did an amazing job on these and I love the adjustability!!! Got any other products on your mind or in the works?? Unless that info is classified![]()
