I considered that a lot. I just have stuff on the door pocket I cannot move (detailing stuff and my garmin gps for mtb)Mine sits in the driverside door pocket - easy to access and can be transfered to a different car if needed.
That's rattlecan "gunmetal" dip. I think the truck is river rock green, so it's kind of a tone on tone situation, like when you get out of the house and realize you picked up your black pants to go with your blue blazer.What color Plastidip? I can't tell if your truck is Riverrock Green, Smokey Topaz, or something else. But I think it all looks good. Very similar combo on mine.
YepHeres dat ass, had to take roof rack off to fit in the garage with 35s on
And can anyone smell this job still? I did a solid axle pickup I used to own over 10yrs ago and I can still smell that grease
While you’re in there may as well do a front diff locker. You only have to undo the diff centreHeres dat ass, had to take roof rack off to fit in the garage with 35s on
That looks really good. Definitely looks better with the lean back.Finally got my Trail Tailor antenna mount adjusted and tweaked for my liking. I bought his CB antenna mast that goes into the regular antenna location. I don’t use my regular AM/FM radio and the factory antenna was broken and inoperative anyways. Also, before the masters of communicative devices chime in, I get it, CB’s are a bit outdated and old tech but my father and I use them to communicate on the farm as well as GMRS. Back to why I’m posting; the mast he sent is straight, no bends, and doesn’t exactly fit with grace into the factory location. He claims this allows for better SWR readings and adjustments but I just couldn’t stand the rake of the antenna. Today I took it all apart and did some adjusting. Got the antenna straight up and down, no torque on the mount due to the misaligned mount to antenna hole angle. Looks much more correct/factory and not so much thrown together. Now to get my SWR’s set. For the beer drinkers; check out Cosmic Pyrokinesis Hazy IPA by Mother Earth Brew Co. this was a one beer job lol.
Actually the lean back photos is the before photo. Now that I’ve bent and adjusted the mast to be straight up and down it fits the guard perfectly with the supplied 3/8 hose the goes over the mast to flush it up with the guard. Before, the angle was so severe that the factory fender guard and antenna mast wouldn’t mesh correctly due to the angle. I had likes and dislikes with the lean, but with it straight up and down I feel it looks more correct in my opinion. It’s all about what you like though, when it’s your vehicle.That looks really good. Definitely looks better with the lean back.
How does it attach inside the guard?
Going to replace my Drain and Fill plugs on the 100 and 80 Series with Low Profile Magnetic ones. They use a 10mm Hex to install and remove.
No more chance of stripping the thin headed OEM fill plugs.
Will chase the threads of each diff and Tcase then install.
I haven't really had problems with the OEM's but what the hell....these are just better.
One new and one newly rebuilt (tonight). The new one also happens to be “Lexus”
The cosmic WTF? Haha, nice post!Finally got my Trail Tailor antenna mount adjusted and tweaked for my liking. I bought his CB antenna mast that goes into the regular antenna location. I don’t use my regular AM/FM radio and the factory antenna was broken and inoperative anyways. Also, before the masters of communicative devices chime in, I get it, CB’s are a bit outdated and old tech but my father and I use them to communicate on the farm as well as GMRS. Back to why I’m posting; the mast he sent is straight, no bends, and doesn’t exactly fit with grace into the factory location causing a slightly severe backwards lean. As well as causing a weird/hard fitment into the factory fender guard. He claims this allows for better SWR readings and adjustments but I just couldn’t stand the rake of the antenna. Today I took it all apart and did some adjusting. Got the antenna straight up and down, no torque on the mount due to the misaligned mount to antenna hole angle. Looks much more correct/factory and not so much thrown together. Now to get my SWR’s set. For the beer drinkers; check out Cosmic Pyrokinesis Hazy IPA by Mother Earth Brew Co. this was a one beer job lol.
